Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 06-26-2009, 10:35 AM   #1
Cement Wall Repairs
Is there a way to fix a damaged cement wall that was hit by a truck, short of tearing the entire wall out and rebuilding? Thanks
muggyfrost is offline   Reply With Quote
Old 06-26-2009, 10:48 AM   #2
Licensed P.E./Home Insp
Aggie67's Avatar
Cement Wall Repairs
I'd have to be there to inspect it before I could make a call on it. The wall could be cracked through at grade, etc. Also it could just be the angle, but is the wall leaning in the lower picture (right side)? A lot of unknowns.
Unfortunately, if I was the property owner, I'd want it replaced because the liability of an insufficient repair would be unacceptable. If you're the property owner, call your insurance company to go after the guy that ran into it. If you're the guy that ran into it, my condolences.
In this case the property owner should cover his butt and call the insurance company and the local building inspector. The insurance company would probably be more interested in paying a claim to replace the wall than it would in paying a claim to someone who had the damaged wall fall on him. The inspector is probably either going to say get an engineer to bless a repair, or flat out say this needs to come down.
Aggie67 is offline   Reply With Quote
Old 06-26-2009, 01:13 PM   #3
Renovation Contractor
Paragon's Avatar
Cement Wall Repairs
EXACTLY WHAT AGGIE SAID!!!!
James D. Van Raden
Owner, Paragon Renovations Moorhead, MN/ Fargo, ND
"Committed to providing the finest renovation services available"
Paragon is offline   Reply With Quote
Considerations when pouring concrete against a stucco wall? clint_nichols Building & Construction 9 09-24-2009 06:28 AM
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 11:24 PM
Replacing wall with engineered Beam pinkertonpv Building & Construction 4 01-15-2009 12:18 AM
exposed brick wall Jrr1099 Carpentry 1 03-25-2008 03:45 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 03:25 PM
