Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-07-2012, 07:50 PM   #1
cement siding mitred corners
I've worked with cement siding quite a bit as a contractor. HAve a new bid in which the customer wants to use Hardie "Artisan"\ product and habve all the corners mitered - no corner trims. Any experience out there?
ebock is offline   Reply With Quote
Old 11-07-2012, 07:57 PM   #2
I'd pass on that idea.
Going to be fun trying to cut that on a compound angle like that.
Old 11-07-2012, 09:52 PM   #3
Sounds like fun, I would take a piece and try the cut first.
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
Old 11-07-2012, 10:21 PM   #4
AHH, SPANS!!!
to get those cuts a cheap beat up miter saw with a blade made for hardie siding would work, or use up your old saw blades on your skilsaw and make a jig to glide the saw base against for each cut. When saw blades get dull on my skilsaw the blade is relegated to the hardie blade pile.
hand drive is offline   Reply With Quote
Old 11-08-2012, 09:27 AM   #5
Moderator
kwikfishron's Avatar
Mitered corners can look great if done right or can be a complete disaster if not. Defiantly not something you want to cut the new guy loose on.
The compound miters have to be absolutely perfect. If the miter angle is off even the littlest bit your corner will start to slowly walk off the wall and is difficult to correct without showing.
I’ve never worked with Hardie Artisan before but have done this with Cedar many times and for me I add 2 hrs. of labor for 8’ of corner.
Hardie does show mitered corners as an option with their Artisan siding. http://www.artisanluxury.com/exterio...erdetail.shtml
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 11-10-2012, 12:04 PM   #6
I would stay away from this install, it is not a product you want to be cutting mitres with. The risk is not worth the reward and dont think you or the home owner will be happy with the result no matter your skill level. If you do take this project I would add 40-50% on top. Good luck
Hardwood Head is offline   Reply With Quote
Felt Paper and Fiber Cement Siding Greg D Building & Construction 29 06-22-2011 09:34 PM
cement board corners ponch37300 Kitchen & Bath Remodeling 3 01-25-2009 06:50 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
