Cement Board For Deck Over Water - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-24-2011, 10:48 PM   #1
Cement board for deck over water
I am looking to replace a deck/pier over water. Wondering if I can use cement board and then lay tile. Trying to compare that cost with cost of composite decking like Trex. Does anyone know of any possible issues with this?
Iklake is offline   Reply With Quote
Old 07-25-2011, 12:32 PM   #2
kwikfishron's Avatar
Rewards Points: 186
You can use Ipe for the cost (or less) of Trex.
The Atlantic City Boardwalk is covered in Ipe so Iím sure it will work for you.
Tile on a pier.
kwikfishron is online now   Reply With Quote
Old 07-25-2011, 02:46 PM   #3
Rewards Points: 5,336
Detail what you think would be the constructive process for the cement board scenario.
Ron
B. Franklin 1759
Old 07-25-2011, 11:13 PM   #4
I would be using in place of plywood with hopes of a longer lasting deck
Old 07-26-2011, 03:17 PM   #5
I don't know how you could build this so you could minimze movement so the tile would stay in place. Too much deflection can and has killed many a tile job indoors.
Ron
B. Franklin 1759
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Correct detail of preformed shower pan meet the cement board of a shower wall eyeglass Building & Construction 0 08-31-2010 03:31 PM
5/8" Fireboard (Paint) meets 1/2" Cement Board (Tile) LeviDIY Building & Construction 9 02-09-2010 10:41 PM
cement porch retaining water jerry1967 Building & Construction 1 11-12-2007 04:49 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
