Ceiling Support For Partition Wall? - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-28-2009, 02:45 PM   #1
hohadcr's Avatar
Rewards Points: 306
Ceiling support for partition wall?
I have a finished room where I want to put up a simple partition wall and make it two rooms.
I know where I want to put the partition wall frame. I also found the two lateral studs in the existing wall where I can screw the partition wall to. The floor is hard wood, so I am guessing that I can just screw the partition wall down into the floor.
The problem comes now. On the existing ceiling, there is no stud over where the top plate of the partition wall frame should go. How can I fix the top plate? Do I just screw the top plate into the drywall of the ceiling?
Thanks a lot.
hohadcr is offline   Reply With Quote
Old 09-28-2009, 02:47 PM   #2
Rewards Points: 79
Thanks a lot.
you will likely need to add some type of blocking between your ceiling joists so that you have something to fasten your top plate into. You don't want to fasten the top plate to drywall only.
I am sure there are others here more experienced than myself that can give you more detailed advice.
Tom5151 is offline   Reply With Quote
Old 09-28-2009, 05:07 PM   #3
Rewards Points: 5,336
Tom hit it on the head. You need to install blocking.
Ron
Old 09-28-2009, 05:44 PM   #4
hohadcr's Avatar
Rewards Points: 306
I just checked (by tapping through the ceiling). I think that the ceiling joints are going perpendicularly with the partition wall. In this case can I just screw the top plae of the partition wall into the joints of the ceiling?
Old 09-28-2009, 08:31 PM   #5
Yes, you can use the method you described.
I guess you lucked out on that one.
Ron
Old 09-28-2009, 08:38 PM   #6
hohadcr's Avatar
Rewards Points: 306
I need a lot of luck when dealing with wood. I will use a stud finder to make sure that I am lucked out this time. Thanks a lot for your help.
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 12:05 PM
Attaching partition wall to ceiling demmett Carpentry 6 08-18-2009 11:08 PM
Support Wall or Not? DelS General DIY Discussions 5 02-24-2009 10:12 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
