ceiling moldings
4K views 4 replies 5 participants last post by  boman47k
Can anyone tell me how to cut inside and outside ceiling moldings? Is there a website with a diagram? While I have cut and installed chair rail and baseboard moldings, I have never installed ceiling moldings.
On the back side of the molding, there are two flat surfaces. One that goes against the wall and the other against the ceiling. You will have to hold the molding in this position while mitering. It's tricky but to get a proper mitre any molding has to be cut in the position it would be in when installed.
#4 ·
Upside down works best in the mitre box for crown but then you have to think upside down. then there is the question of to cope or not to cope. Coping is a technique professional carpenters use on inside corners. It is easy to show someone but not too easy to describe in words. There might be someone at the hd who could show you but i wouldn't count on that being correct. Usually for painted crown a couple of 45 degree cuts for the inside corner will do but that would not be how I would do it. HS
