Ceiling Molding - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-19-2009, 09:36 PM   #1
ceiling molding
Has anyone used or have examples of using 'flat' molding around the ceiling instead of crown or cove molding? I want to add something to my ceilings but maybe a little more subtle than a traditional crown. Would it be unheard of to use casing along the ceiling?
sarahc is offline   Reply With Quote
Old 12-19-2009, 10:24 PM   #2
Rewards Points: 5,336
Iy might look a little anemic, especially in a larger room. You might try building up a series of flat moldings to give it some character.
It's a, "personal taste" thing.
Ron
Old 12-20-2009, 05:18 AM   #3
A casing or baseboard is not unheard of. I like the idea above of a built up trim.
Old 12-20-2009, 06:41 AM   #4
Remodeling Contractor
It can be done. The idea of molding on the ceiling is to create a shadowed effect which breaks the line between the wall and ceiling allowing the illusion of a higher ceiling. The angled crown does this better than square lines would.
Old 12-21-2009, 11:53 AM   #5
I saw a presentation on an "affordable" building in Atlanta. The architechect specified two 1x4s as crown molding. One went up flat on the ceiling first, and then the other went flat on the wall under it. He had a picture and I thought it looked pretty good.
pyper is offline   Reply With Quote
How to remove plaster molding from popcorn plaster ceiling?? clone477 Building & Construction 2 12-16-2009 12:58 AM
Ceiling Molding BESIDES Crown? Say Flat Stock? Scotsman General DIY Discussions 9 12-07-2009 02:02 PM
Suspended ceiling with crown molding ncomerci Remodeling 2 11-25-2009 03:55 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
ceiling white - crown molding color question remodelingagain Interior Decorating 3 06-06-2008 01:16 PM
