| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Installing a Light Fixture Box
by Expert Village
Hi, this is Jon and in this clip we will be installing our fixture box. Now, with the can light that we pulled out, the diameter is about six inches. However, the diameter for our mounting plate is only about four inches. Now, because our opening is so... Read More »
What is an I-Joist?
by Expert Village
This is Ben Ingham with Expert Village talking about a walk out basement. Once we get this wall corrected whatever problems and however we can go about getting it corrected and then the next step in the next procedure is to be sure it is reinforce and it... Read More »
How to Paint the Bathroom Ceiling
by Expert Village
Hi, this is Jon on behalf of Expert Village. In this video clip we will be going through part 2 for painting our ceiling. We're going to start by painting a perimeter around the ceiling. Now if you get a little bit on the wall that's alright, because we... Read More »
Matching Wall Texture to Sheetrock Repair
by Expert Village
My name is Shannon Kniep on behalf of expert village. And so you want to make sure that you do this process of sanding and re-coating at least three times it sometimes requires up to four depending on how much variation you have in your planks on your... Read More »
How to Tile a Ceiling
by eHow.com
Ceilings in an older house can be unsightly. A relatively inexpensive way to solve the problem is to install ceiling tile. While you can attach ceiling tile directly to the ceiling with glue, it's easier to install furring strips and attach the ceiling... Read More »
