Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-10-2013, 08:40 PM   #1
Ceiling Joists
I'm decoupling my basement ceiling from a few new rooms I'm building. Current height is 9' 4" and I plan to run new joists on the walls at about 8' 4".
1) do joists run across top plate with toenails or inside walls with hangers?
2) is 2x8 overkill for supporting a double 5/8 drywall celing? Trying to prevent sag..
Cheers!
.:RoKsTaR:. is offline   Reply With Quote
Old 02-10-2013, 08:44 PM   #2
Ceiling Joists
what will the the joist spans ?
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 02-10-2013, 08:50 PM   #3
Ceiling Joists
24" would be best for sound isolation but I could manage 16 or 12 if I had to
Old 02-10-2013, 08:59 PM   #4
Framing Contractor
Ceiling Joists
He asked the span of the joists...not the on center spacing.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 02-10-2013, 09:03 PM   #5
Ceiling Joists
haha, right :P
Roughly 10.5 feet, depending on if the hang between walls or sit on plates
Old 02-10-2013, 09:11 PM   #6
Moderator
Ceiling Joists
http://publicecodes.cyberregs.com/ic...002_par023.htm
Gary
PS. be sure to add fire-blocking at the new ceiling level in the frame wall.
Clothes taking longer to dry?
Old 02-10-2013, 09:25 PM   #7
Ceiling Joists
Because its so cold in Canada, we don't need fireblocking :P
Old 02-10-2013, 09:32 PM   #8
Roofmaster
Ceiling Joists
Decoupling??? WTF? WHy not just put in a dropped ceiling so you have access to all your services? 2 x 2 is nice.
" A lot of men build things, and a lot of things fall down "
Old 02-10-2013, 09:51 PM   #9
Ceiling Joists
Most efficient way to soundproof is to decouple, sound will transfer through anything that touches.
Old 02-10-2013, 11:16 PM   #10
Ceiling Joists
for 10.5' , 2x6's would work just fine.
Old 02-10-2013, 11:43 PM   #11
Ceiling Joists
good to know
Old 02-11-2013, 08:59 AM   #12
Average Joe/ex-Navy IC3
gregzoll's Avatar
Ceiling Joists
No, most efficient way is to not crank up the tv or music, in that it disturbs others in the home. That with knowing how to properly build or retro-fit the home, so sound does not transmit to the other floors.
Decoupling is a waste, and not needed unless you are either creating a sound or practice studio. If doing this for a home theater, it is more over kill than anything.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
Old 02-11-2013, 10:51 AM   #13
Ceiling Joists
BINGO! I'm a professional guitarist and I need 2 rooms to record and mix in :P Not only to shield sound from upstairs, but also to protect my recordings from having twin 4 year olds and wood floor noise bleeding in to all the tracks :P
Old 02-11-2013, 11:45 AM   #14
Roofmaster
Ceiling Joists
Maybe you should listen to the twins. What they have to say will mean more in the long run than anything else you'll hear. Especially the so called "tracks" Ive heard lately. Nothing but noise. Id rather hear the fan running.
We used to have a saying, "Those that cant play good, play loud" does that still apply?
Old 02-11-2013, 12:55 PM   #15
Ceiling Joists
What are you talking about? Although my name may say rokstar, I'm a jazz guitarist, composer, and private guitar teacher. I have highly tuned hearing and need complete silence to mix/master music properly. If my kids hear me playing, they just want to play with me too. That in itself is ok when I'm not teaching, but I need to work in silence so they don't become upset that we can't jam.
I don't need advice about music, I've got 2 degrees and 20 years of playing to help with that :P
Level basement ceiling joists to install drywall hrm Drywall & Plaster 4 12-26-2012 10:02 PM
Move joists for higher ceiling jgrohol Building & Construction 11 10-03-2012 05:24 PM
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 01:10 PM
Garage ceiling joists and beam question Truth Building & Construction 8 01-05-2012 08:52 PM
Sagging Ceiling Joists Steve Burke Carpentry 12 12-13-2009 06:18 PM
