Originally Posted by bigoldgeek
We want to open up our master bedroom. To do so, we will remove the closet that runs the length of the room. The front wall of the closet is 12 feet from the outside wall, The back wall is the load bearing wall (not to be removed) with 2 x 8 ceiling joist spaced at 12 inches. Removing the front wall of the closet increases the span by 2-3 feet for a total span of 15 feet. House was built in 1954, I can't really tell what the wood type is but we live in Wisconsin and the wood is probably native to the state.
Most of the tables I have looked at for this say the minimum maximum is 18 feet(based on wood type). Just checking to see if this makes sense.
thanks
A span of 18' is too long for a 2x8. Before you did anything, you need to know what's going on with the structure in the ceiling above this room.
Is the wall you're removing, holding up the ceiling? Is it a load bearing wall.
You need to go up in the attic and look around. Take some pictures and tell us the relationship of the joists to the closet wall.
Ron
