Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-30-2007, 06:12 PM   #1
snoshoe
Lightbulb
ceiling fan support
Have cathedral ceiling with no support joists, but have one rafter about 4 inches off center...ceiling angle is 18 degrees. My scenario is to cut a 2X12, angle sides to 18 degrees, drill 4 inch hole in center(which I have split two pieces of 2X12 already trying to do...any ideas?), mount the fan box in the hole,secured by steel rod across top of 2X12 so it won't fall through, and mount the finished 2X12 to ceiling center, using lag bolts to attach to the one rafter and regular wood screws on the other side to attach to the ceiling boards. Is there a better way...without cutting into the ceiling and trying to span rafters with a 2X4? Also, any ideas for quickly cutting that 4" hole in the 2X12 for the electrical box? I tried, using a 3 inch hole saw, but don't know how to enlarge it to 4 inches without splitting the wood...which I have already done on two pieces. Any ideas are appreciated, as long as I don't have to cut into the ceiling and can mount the thing dead center, not angled on the ceiling. Thanks.
triplnikl is offline   Reply With Quote
Old 01-30-2007, 08:07 PM   #2
jproffer's Avatar
ceiling fan support
Try to find one of these:
Should be at most home improvement centers. They fit through a standard ceiling box opening and expand into the joists on both sides. The box slides to any position on the bar so centering is not a problem.
EDIT: OK, I read some more on the product shown and it is for accessible spaces. They look similar for inaccessible spaces, just make sure that's what you get.
jproffer is offline   Reply With Quote
Old 01-31-2007, 12:08 PM   #3
snoshoe
ceiling fan support
Thanks for the info. I had considered these joist spanners, but my problem is that the only spanning I can do is between rafters, which are set at 18 degrees. Being totally enclosed, I would have to hope that there would be enough bite on a rafter set at that angle so that the box would hang level. I may end up biting the bullet on that and making a wild stab at it, but I don't want to cut into the ceiling unless I absolutely have to. Thanks again.
Old 11-19-2008, 10:17 AM   #4
bradnailer's Avatar
ceiling fan support
I'm not sure about the electrical code in your area but have you considered lag bolting the fan mounting bracket directly to a rafter. It seems to me that if you make all your electrical connections inside the fan housing you would not violate any electrical code.
bradnailer is offline   Reply With Quote
Old 03-05-2009, 09:50 PM   #5
ceiling fan support
This fan support, is it possible to just swap it into a standard light box cut out? how does is fasten? I currently have a light box attached to a joist in standard fashion, but I want to install a fan. I understand that this expands between the joists, but how the heck would you get a drill in there to attach it? I'm trying not to cut the drywall around the existing light prewire box. Will this work or is there something else? Also, what is the brand name of this product? I can't read it or enlarge it to see properly. Thanks a lot. just found this site and love it.
Benjamin.
benjitsu is offline   Reply With Quote
Old 03-06-2009, 04:47 PM   #6
ceiling fan support
Ben, you are better off starting a new thread to get an answer, or do a search on here, you are posting in a very old thread.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
More On This Topic
The outside roof pitch on your home can be made more attractive by increasing the pitch of the roof. Increasing the roof pitch also provides a more efficient way for rain and snow to drain more easily off of the roof. Read on to learn more. Read More »
How to Use a Quick Square
How to Use a Quick Square by Expert Village
Hi! I'm Drew Finn here for Expert Village. We are going to talk about standard hand tools and how to use them. This is a quick square and it is used for framing. I find it very handy around the house just to do quick little jobs. It's got a lip on here... Read More »
And now we're going to talk about, as part of the floor, the hole covers that are used and the holes that are designed to be used inside the shanty. This shanty is elevated, the floor is basically elevated anywhere between six and twelve inches off of... Read More »
Now I'm going to demonstrate how to cut the neck hole. First you need to find the center of the fabric so we're going to fold our square corner to corner like that and you have a triangle and then this is the center of the poncho. Now for a small child I... Read More »
We need to measure for the top ceiling and the bottom of the bat house. The top of the ceiling our measurements are three inches by eleven and a half inches. That will be the top of the bat house. For the bottom of the bat house the bats require one inch... Read More »
Paint peeling off Bathroom Ceiling!!! armen30 Painting 16 02-18-2010 12:43 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
installing a ceiling ladder jerry1967 Carpentry 6 11-21-2006 12:18 AM
Rod Lengths for Ceiling Fans and Mini Pendants Not Sure Electrical 6 10-25-2006 12:23 AM
Rafter Thrust / Cathedral Ceiling sseeley Carpentry 8 10-06-2005 12:19 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
