Cedar Water Tank - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-26-2010, 06:10 PM   #1
cedar water tank
I'd like to build a 6' X 2 1/2' X 18" water "pool" for my two labs so they can soak and cool down in this heat. It will go in the 5' X 18' run. I need to know if I can use cedar boards, like tongue and groove flooring or the like. Would it swell and seal? I thought of cutting down an old stock tank, but the ones that aren't being used are in really bad shape.
Any suggestions are welcome.
Thank you.
roeula is offline   Reply With Quote
Old 08-26-2010, 06:30 PM   #2
kwikfishron's Avatar
Rewards Points: 356
Your Cedar plan is an expensive fail.
Find something else that will already hold water and bury it.
Wally World Kiddy Pool comes to my mind.
kwikfishron is offline   Reply With Quote
Old 08-26-2010, 06:35 PM   #3
thanks for the idea
Thank you for your reply. Only problem with that is, the run is cemented for ease of clean-up. I have a plastic kiddy pool on our deck that they use, but I'd like to come up with something I can put in the run so they can use it when I'm not at home to supervise.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Flooded Salt Tank in Kenmore H2O Softener whitedavidp Plumbing 2 01-07-2010 12:05 PM
Well Water Pressure Tank for Air? Reilley Plumbing 8 02-20-2009 12:53 PM
How much would you charge to plumb a hot water tank? Piedmont Plumbing 12 08-20-2008 11:35 PM
