Cedar Vs. Spruce Trim? - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-31-2011, 09:43 AM   #1
cedar vs. Spruce trim?
State of WA - which holds up better? Cedar or spruce for wood trim on the house?
Chriswake is offline   Reply With Quote
Old 12-31-2011, 10:54 AM   #2
Stairguy
Millertyme's Avatar
Rewards Points: 508
Cedar
Millertyme is offline   Reply With Quote
Old 12-31-2011, 10:56 AM   #3
Rewards Points: 13,712
A composit trim would even be better, no chance of rot, no painting or staining.
Old 12-31-2011, 01:22 PM   #4
kwikfishron's Avatar
Rewards Points: 586
Defiantly Cedar. If it’s going to paint look into clear finger jointed cedar.
The FJ Cedar has a real clean look and comes already primed.
kwikfishron is online now   Reply With Quote
Old 12-31-2011, 02:56 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,202
spruce doesnt work very well when it comes to aesthetic finish its more for structural purposes, cedar will do a much better job.. if its for exterior i would avoid finger joint as there are more joints to fail with being exposed to the elements, stick with solid peices of cedar
woodworkbykirk is online now   Reply With Quote
Old 01-01-2012, 04:29 AM   #6
Rewards Points: 586
Iíve used FJ Clear Red Cedar for paint grade exterior trim for almost twenty years and never had any issues with it falling apart.
I get the FJ for close to the same price as tight knot. Painted TK never looks right unless you spend the time to fill holes and sand it all.
I would never recommend painting solid clear cedar simply because the cost doesnít make it practical.
Old 01-01-2012, 07:27 AM   #7
I live in VA and the last thing anyone would want to install here is cedar. The reason being, boring Bees. Look like Bumble bees but love to make a home in soft untreated wood. They make a hole about 3/8" perfectly round hole then make a 90% turn and hollow out a huge area to lay there larve.
I've never once seen paint stick to Cedar, seems to be to oily a wood. I use soild colored stain instead.
Old 01-01-2012, 03:48 PM   #8
Rewards Points: 586
Youíre kidding, right?
I canít say Iíve ever dealt with boring bees in my neck of the woods but painted cedar lap siding has been around forever and yes, paint sticks to it.
Old 01-01-2012, 08:48 PM   #9
it may be do to different climates that finger joint holds up better, im in a maritime environment where finger joint wont last 2 years before it starts to fall apart
New basebords and trim are white but all window frames are stained cedar? mibson Interior Decorating 0 01-22-2011 01:27 PM
repairing damaged cedar trim Master Brian Remodeling 3 09-10-2010 12:30 AM
Fascia: 2x6 or 1x6? cedar or spruce? Dodah Roofing/Siding 11 06-07-2009 08:50 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
