Cedar Siding - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-02-2009, 08:40 AM   #1
cedar siding
I have 1x6 t&g vertical siding that was damaged by hail with dents what is the best way to remove the denting and restaining
mxpoor is offline   Reply With Quote
Old 09-02-2009, 08:50 AM   #2
Registered User
Termite's Avatar
There's no way to remove dents from wood unless you want to paint the wood to cover the repair.
Old 09-02-2009, 02:33 PM   #3
Registered User
Rewards Points: 4,902
Before you demo it, take a steam iron from the laundry, wet the dent, apply on medium or low, remove before wood burns, just 5 seconds- experiment. Try with steam, if stubborn. Apply again after wetting, till it's out. If burning, use a material between. I've done this on cedar decking for years and years.
Be safe, G
Installing fiber cement siding over existing cedar siding heron Remodeling 3 07-25-2009 12:17 AM
Vinyl siding over cedar siding dbldee20 Remodeling 8 02-21-2009 08:06 AM
Cedar siding my best option? TheNiceGuy Building & Construction 8 09-15-2008 07:44 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
