Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-28-2010, 10:39 AM   #1
Cedar Shingles
We recently purchased a house with cedar shingles, unpainted. Some of the shingles have been replaced and therefore do not match the already weathered shingles. Is there some way to speed up the weathering or to stain the new shingles so they darken to the weather look faster? The house looks a bit ragedy to me with the two different shingles on the front of the house.
Lynda
Lynda Packer is offline   Reply With Quote
Old 10-28-2010, 11:53 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Cedar Shingles
You can use a semi-transparent gray stain to help blend the cedar shingles faster. If you really have a lot of new shingles, you might want to consider spraying the entire roof or at least the front).
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Where Cedar Siding Meets Shingles? echase Building & Construction 3 04-08-2010 06:11 PM
Replacing Cedar Shingles tstanley Roofing 2 03-09-2010 03:52 AM
Roofing cabin with cedar shingles skolfoppa Roofing 3 09-10-2008 10:31 PM
Mixture for soaking cedar shingles Keuka Lake Painting 2 06-19-2008 10:22 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
