Cedar Planks? - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-11-2008, 01:15 PM   #1
Cedar Planks?
My husband and I are purchasing a 1922 stick built home. In all of the bedrooms the walls are cedar tongue and groove. What type of cedar would be used for this ( I know for sure that it is not eastern red cedar, there are no white knots or patches) and would it be possible to remove the cedar and reuse it as flooring else where in the house? I do realize it is a soft wood but is bamboo softer?
cseibel05 is offline   Reply With Quote
Old 08-11-2008, 03:26 PM   #2
Drywall contractor
Rewards Points: 1,070
Not my field of expertise, but if you're sure it's cedar, it would seem to me it's an awfully soft wood for flooring. Harder woods such as oak and pine are normally used. If taken down carefully (it's most likely nailed through the tongue) it could be reused. I just don't think it's a good candidate for flooring. Someone may chime in and prove me wrong. It would make a great looking ceiling if it's not on the ceilings already.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 08-11-2008, 04:24 PM   #3
Registered User
Termite's Avatar
Cedar is not used for flooring, except on decks. It is much too soft. Western red cedar is commonly used to make siding or beaded ceiling. But in 1922, it is hard to say.
You mentioned bamboo...It is as hard as a rock and makes excellent flooring.
The softest material used for flooring these days would probably be fir, which isn't very common in the flooring biz anymore.
Old 08-11-2008, 09:07 PM   #4
Extreme DIY'r Adk's, NY
Rewards Points: 272
I love cedar... post a pic!
Chances are you will ruin the tongues removing in, in fact I would bet you salvage very little. Wood that old will be very dry and brittle. You could however, if you must remove it, rip off the tongues on the table saw and make some gorgeous molding perhaps?
No chance for flooring, it's even softer than southern yellow pine which IMO was the softest wood ever used for flooring and I dont ever see it used anymore.
...and yes bamboo is hard as nails and very durable... and also pricey; mostly due to the manufacturing process and low qty runs I would venture to guess.
crecore is offline   Reply With Quote
Old 08-12-2008, 12:10 PM   #5
Cedar in 1922 looked much different than cedar does today. Those knots and white patches (sap wood) are caused by harvesting small, immature trees. When you see old growth cedar or fir it is much darker, with fewer knots - if any. I would bet that it's red cedar - it's the most recognizable. If it was yellow cedar, cedar of lebanon, cypress, etc etc, someone without prior experience wouldn't know it was cedar to look at it.
whiskeykid is offline   Reply With Quote
Preparing 5/16" cedar planks Clutchcargo Carpentry 3 07-07-2008 08:57 AM
Replacing Asphalt w/ Cedar Shingle pbehnke Roofing/Siding 1 05-06-2008 01:28 PM
Laminate Flooring and a Cedar Closet StevenS Flooring 5 03-17-2008 11:28 AM
cedar shakes: nails vs staples.... MichaelinOmaha Roofing/Siding 5 10-12-2006 05:22 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
