#1 |
cedar deck boards peeling
I put in a cedar deck and put a clear stain on it. During the winter I brushed of the deck and now the broads are peeling. Does anybody know what what would cause this peeling?
#2 |
You might have put the stain on too thick. You will probably need to remove it all, let it dry throughly and try again.
Did you wipe off the excess and any places it puddled? A few light coats are better then one heavy coat. Did you put anything on top of the stain? Ron |
#3 | |
cedar deck boards peelingQuote:
#4 |
Post a picture.
Ron |
#5 |
It sounds like you used a product that sits on top of the surface instead of soaking into the surface. Cedar doesn't allow bonding very easily because of the tannins in the wood, especially on a horizontal surface. Try sanding it all down because eventually it will all peel off. Try an oil based stain and keep the coats even and thin and you will have better luck.
Josh Jaros Remodeling in The Woodlands, Texas To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| Composite Deck Boards | dgoodwin3364 | Carpentry | 10 | 06-05-2009 12:09 PM |
| Building a new deck....and creative uses of granite scrap in outdoor living space | Rhizzlebop | Building & Construction | 9 | 05-15-2009 12:17 PM |
| cedar deck looks like crap | silky | Painting | 16 | 05-02-2009 11:42 PM |
| Climatizing Cedar boards | Outbacker | Building & Construction | 2 | 03-07-2006 10:34 PM |
| Cedar Deck boards | Outbacker | Painting | 2 | 03-04-2006 02:12 PM |
