Caulking Replacement Window Trim - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-28-2011, 02:27 PM   #1
I installed vinyl replacement windows throughout the house. I used insulating foam at the jambs and everything seemed to be sealed however I now see considerable air coming up at the sills. I want to put a bead of caulk there to seal the gap. My problem is that the exsisting trim was stained to match attached paneling. So I now have a vinyl window and stained darker trim. I believe a white caulk would look terrible. Even a colored caulk would look weird. Caulking and using a small quarter round molding (stained) to cover it has some appeal until I realize all the various shades of trim there are.
Can anyone suggest a solution? I might have been well served to put a bead of caulk on the vinyl window bottom where it was to meet the sill before installing, but its too late now. (I'm wondering if that's common practice by the way.) I'm going to try to attach a picture.
Thanks.
barbe44 is offline   Reply With Quote
Old 02-28-2011, 04:21 PM   #2
masking tape and/or clear caulk
mrgins is offline   Reply With Quote
Old 02-28-2011, 10:28 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Always match your caulk to the face, not the return. If you are skilled, white caulk will look good. If not, you might try clear as previously suggested. Definitely DO NOT use brown.... Do you have any way to access this from the exterior? If there is a sill angle/expander, you can often remove it to add additional foam.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Need help caulking and filling nail holes in my trim hadees Painting 13 11-25-2012 11:32 PM
Input RE: Updating Exterior Window Trim Greg D Remodeling 3 04-16-2010 10:54 AM
Stool and Apron Window Trim Style Advice DIYCarp Carpentry 8 01-24-2009 10:31 AM
fixing cracked caulking on mdf painted trim cinnabon Painting 5 04-15-2008 05:49 AM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-14-2005 12:59 AM
