Caulking For Pvc Brick Molding - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-22-2010, 09:16 PM   #1
caulking for pvc brick molding
I have just finished putting on pvc brick molding and jam on my garage door, however I was advised to use s s screws to attach the pieces. I have and i have sunk the heads slightly and want to cover seal the holes. What caulking should I use to seal the hole in this material?? Thanks in advance for all the help.
cvbs
cvbs is offline   Reply With Quote
Old 07-22-2010, 10:32 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,212
If you are going to paint, then siliconized acrylic. If not, pure silicon.
Coastal South Carolina
Old 07-23-2010, 06:23 AM   #3
Thanks for the reply rjniles..... " If you are going to paint, then siliconized acrylic. If not, pure silicon."
I just heard from another person locally to use a latex based, what are your thoughts?
Old 07-23-2010, 07:09 AM   #4
A "Handy Husband"
rjniles's Avatar
We are taking the same thing, the full name is siliconized acrylic latex caulk.
Old 07-23-2010, 05:17 PM   #5
Thanks for the clarification; much appreciated.
pvc brick molding formyson1 Carpentry 3 06-29-2010 08:20 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
Caulking Brick Blondesense Building & Construction 8 02-15-2009 11:51 AM
Sealing historic brick tenzo General DIY Discussions 2 11-22-2008 03:04 PM
pvc brick molding ramies Building & Construction 6 07-13-2008 08:09 PM
