Casing Drywalled Windows? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-10-2011, 12:53 PM   #16
Rewards Points: 590
I just ordered the shutters and they measured assuming the drywall would stay. I will not mess with these windows since the shutter people will essentially 'case' them when they install the shutters in the drywalled opening. I was really just wondering if it would be a nicer looking shutter install if the window had wood casing rather than drywall casing, but it turns out that makes no difference in the final appearance. This was just a secondary question, that's all.
In the windows that **will not** have shutters, I plan to case those by replacing the drywall with wood, as recommended.
Sorry for the confusion!
noone is offline   Reply With Quote
Old 10-10-2011, 01:02 PM   #17
cocobolo's Avatar
Rewards Points: 6,098
Not really any confusion noone, good luck with the install.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 10-10-2011, 06:03 PM   #18
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,242
in regards to losing 1/2" or gaining 1/2" in the opening it all depends on the window itself. if the window has the check in it that recieves the jamb extension your opening will stay the same because they take both 1/2" drywall and 3/4 wood. the face is still going to be in the same spot
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
cocobolo (10-10-2011)
Any restitution for VERY late windows? msbriggs Building & Construction 21 10-05-2010 06:25 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
Window Casing around Vinyl Windows tcoshea Building & Construction 3 11-28-2007 09:52 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
