#1 |
Casing drywalled windows?
I want to add casing to some windows that were built in with drywall. I don't want to have to rip out the drywall and 'really' case them, so can I just add case molding around the edges and then paint the inside of the window semi-gloss white to match the trim? Standard practice? Do you also try and add a reveal by offsetting the casing off the edge of the drywall or is this generally impossible in this application because of the varied straightness of drywall edges?
It's smooth drywall and these windows will not have any shutters installed in them. The windows with shutters already have casing which was installed with the shutters. Last edited by noone; 10-09-2011 at 08:49 AM. |
#2 |
You CAN do almost anything you want. Whether it will satisfy you or not is another story. This is only my opinion, but what you are proposing to do will not look very good.
#3 |
KemoSabe
I've done it in the past. The reveal is a must, especially if the corner bead is questionable. You'll want the legs to be plumb and the head level, or as close as is practical with the bead situation. In any case, it should at least look straight to the eye.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks. |
#4 |
Super Moderator
Do be careful if you are using a brad nailer--the corner bead is metal --if the nails go straight in they will usually pierce the metal----however some will bend and fish hook---nailing your finger tips--
Keep your fingers well away from the area you are nailing.---Mike---
New members: Adding your location to your profile helps in many ways.--M-- |
| The Following User Says Thank You to oh'mike For This Useful Post: | cocobolo (10-09-2011) |
#5 |
noone: If I were you I would remove the drywall "casing" and replace it with wood.
IMO it would very likely look better, and it will certainly stand up to any possible knocks in future. The cost would really be minimal, and you would have something solid to nail your outside trim to.
Just an old guy messin' with bits of wood... ...the friendliest thread on the site! Come on by. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#6 |
journeyman carpenter
in regards to shooting the corner bead,, if its plastic theres a good chance the nails will cause the skim coat to explode.. its why i hate plastic corner bead. especially in reno situations... sometimes the nail wont draw the trim to the wall so you have to shoot closer to the corner for it to hold
dont even get me started on steel stud |
#7 | |
Casing drywalled windows?Quote:
| The Following User Says Thank You to cocobolo For This Useful Post: | woodworkbykirk (10-10-2011) |
#8 | |
Now I'm wondering if the shutters I am buying and will be installed in 6 weeks should be installed by removing the drywall as well. I believe they are going to be installed as one big frame complete with molding nailed over the drywall. I dont think they do this anyways but just wondering. Thanks for the advice. |
#9 | |
What I think you are saying is that the shutters will be made to fit the opening, is that right? If so, I would have the drywall out of there in a heartbeat. Make sure they get the measurement back to the framing.
#10 |
I called them. They took the measurements from the drywall edges. End result will be the same regardless if it is a drywall or wood jamb- they build the shutter with it's own built in frame and install in opening. Good to go.
#11 | |
Not sure if the extra 1" would add much more light, just a thought.
#12 |
Mod
After you trim out with wood you lose ½”.
I’d find out the exact size of the shutters before modifying anything.
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. |
| The Following User Says Thank You to kwikfishron For This Useful Post: | woodworkbykirk (10-10-2011) |
#13 | |
Yes, if the company has started to make the shutters, I wouldn't bother to change anything.
#14 |
Mod
You're taking away ½” of Sheetrock then your adding ¾” of wood on each side so you lose ½” from the finished opening that the shutters were measured for.
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. Last edited by kwikfishron; 10-10-2011 at 12:51 PM. |
#15 | |
Actually, I wouldn't do that, I would use 1/2" wood...but since I'm not doing it I guess it's up to noone to decide. Don't forget that I machine all my own wood, so if I need 1/2" then that's what I make. No argument with your logic though!
| Display Modes | |
| Any restitution for VERY late windows? | msbriggs | Building & Construction | 21 | 10-05-2010 07:25 AM |
| Windows XP Mode in Windows 7! | poppameth | PC Repairs & Upgrades | 5 | 04-28-2009 01:18 PM |
| Window Casing around Vinyl Windows | tcoshea | Building & Construction | 3 | 11-28-2007 10:52 PM |
| How do I install new windows? | RickT | Carpentry | 17 | 10-12-2006 07:06 PM |
