-   -   Casement versus double hung windows (http://www.diychatroom.com/f14/casement-versus-double-hung-windows-7048/)
Sammy 03-11-2007 01:09 PM
I'm getting ready to replace my 1970's wooden/glazed windows.
I have used the wood clad Pella double hungs in the past but never liked the plastic side pieces. Thinking about going with the Pella clad casements as it seems they would seal better.
I'm looking for long term quality/efficiency as I plan to be here [hopefully] for awhile.
Does anybody have any pro/con's on the casements?
BigJimmy 03-12-2007 12:59 PM
Presenting: MY TWO CENTS!
I prefer casements since they do not have the horizontal break due to the sashes. Further, I think that they tend to seal better since once you close them, you can engage the lock(s) that pulls the moveable piece tight to the frame.
cibula11 03-12-2007 01:04 PM
I think casements seem a little more efficient as well.
fhivinylwindows 03-12-2007 04:03 PM
Think about where the wind comes from when you decide on a left crank or a right crank. If the wind comes from one side and hits the window you can get some great ventilation during the summer.
Sammy 03-13-2007 05:50 PM
Thanks to all!
I was leaning towards the casments for a lot of the reasons all of you you mentioned here, Better seal, no addtional horizontal crack between sections of the window etc. [plus thats what my wife wants]
The only drawback I see to casements is that the window is more exposed to the weather should it be open when a rain comes.
Thanks again
fhivinylwindows 03-13-2007 09:41 PM
Sammy, if you go with the Pella casements use a poly (spar) that has UV inhibitors in it. When you open the window the sun will begin to eat away at your finish. If you need double casements be sure to buy the mull kits if you are using stock windows.
Sammy 03-14-2007 05:41 PM
Thanks!
BigJimmy 03-15-2007 08:21 AM
What other reason do you need??!!:wink:
