Cased Opening - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-02-2012, 08:18 AM   #1
cased opening
we have base and shoe molding around several opening in our home, we want to add trim around the openings, is there a way to do this with out removing the base molding?
cvstearns is offline   Reply With Quote
Old 09-02-2012, 08:33 AM   #2
DIY staff
Rewards Points: 7,174
Yep----you need a Multi-tool---they allow you to make small,accurate cuts --like removing unneeded sections of trim.
I have a Harbor Freight one---the better of the two that they sell.
Tough tool and the blades are cheaper than any other brand that I have seen.
AtlanticWBConst. (09-02-2012)
Old 09-02-2012, 08:41 AM   #3
DIY staff
Old 09-02-2012, 09:13 AM   #4
Rewards Points: 13,714
Post a picture of what you have.
What kind of moulding are you trying to add?
Old 09-02-2012, 09:17 AM   #5
DIY staff
He (or she) wants to case and trim the openings--so the existing base is in the way of the new casing.
Old 09-02-2012, 09:20 AM   #6
I get that, and understand what your suggesting Mike.
Just trying to get a handle on the bigger picture.
Old 09-02-2012, 10:06 AM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Not everyone has access to a digital camera, or is familiar to the process of uploading and posting pics.
The original post pretty much explains clearly what they the OP wants to do. Mike's suggestion of using a multi-tool is the best method, and the method (and tool) that we standardly use for such applications.
- Build Well -
Cased Opening BuckyB Carpentry 2 08-09-2011 05:20 PM
Design question for cased openings clb2010 Remodeling 2 04-13-2010 06:14 PM
framing a 30" cased opening with no door (a walkthru) chrisjohns Carpentry 4 04-12-2010 05:48 PM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 01:37 PM
Finishing opening for closet Frank_N_Stein Carpentry 11 12-24-2008 08:52 PM
