Carsiding Doesn't Meet In Corners - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-27-2010, 09:51 AM   #1
carsiding doesn't meet in corners
My husband and I built this 3 season room onto our house. We thought that a 45 degree angle with the boards would look interesting. It did. What happened though, is that we didnt get the cuts close enough to meet correctly in the corners. What type of molding would look good and cover this imperfection we created.
thibadop is offline   Reply With Quote
Old 03-27-2010, 11:22 AM   #2
kwikfishron's Avatar
Rewards Points: 1,008
Got a picture?
kwikfishron is online now   Reply With Quote
Old 03-27-2010, 12:03 PM   #3
I have had trouble posting a picture. There is a gap of about a 1/4" in several places.
Old 03-27-2010, 12:14 PM   #4
Sounds like you made a good try on something a seasoned carpenter would have found to be a good challange.
Walls are never 100% plumb and the adjustments (shimming and cutting each board to fit) would have shown A++ craftsmanship if it would have worked.
depending on the gaps consider small cove molding, inside corner, or 3/4 round ... all depends on the look you like. Get some samples and try them out.
I applaud your good try.
Big Bob is offline   Reply With Quote
The Following User Says Thank You to Big Bob For This Useful Post:
thibadop (03-27-2010)
Old 03-27-2010, 12:56 PM   #5
carsiding
thanks BigBob,
That is exactly what I thought, but my husband wanted to try to make some moldings and I have seen this semi crude work before and didnt want to make this grand looking room look like we did it.
Old 03-27-2010, 01:16 PM   #6
The grand master Norm A... can make creating moldings look easy... sure if a five star Router table and every bit is at your disposal..along with an unlimited supply of stock to play with..all paid for by the TV producers or equipment donated by the manufacturer ( for a plug on National TV).
Ooops! maybe hubby was looking for an opportunity to tool up! Consider his joy in creating a solution and calling this space his creation. (Priceless)
Either Way.
I'm sure you guys will enjoy the space and be proud knowing you did it yourselves.
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 03:10 PM
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
typical room dimensions + corners? cwm9 Drywall & Plaster 3 03-18-2010 11:54 PM
Does T&G Carsiding Meet Code? cibula11 Building & Construction 2 01-19-2010 08:51 PM
cement board corners ponch37300 Kitchen & Bath Remodeling 3 01-25-2009 05:50 PM
