Carsiding - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-14-2013, 10:34 AM   #1
Carsiding
Hello I am hoping to attach carsiding to the ceiling of a patio cover I built. Is it poosible to attach the carsiding directly to the truss bottom chord
Musaw17 is offline   Reply With Quote
Old 05-14-2013, 10:42 AM   #2
Old School
Willie T's Avatar
You do not state where you live, and extremes of weather do make a difference in doing this... individual trusses will move at varying rates, and in differing amounts, thereby sometimes buckling whatever is directly mounted to them.
Willie T
Old 05-14-2013, 11:46 AM   #3
I live in Central Illinois
Old 05-14-2013, 12:22 PM   #4
Rewards Points: 626
I never heard of car siding? Car decking yes but car siding what the heck is that?
Nailbags is offline   Reply With Quote
Old 05-14-2013, 12:52 PM   #5
Rewards Points: 744
http://www.google.com/search?q=car+s...w=1680&bih=918
Seattle2k is offline   Reply With Quote
Old 05-14-2013, 01:01 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 802
I have always called it box car siding, in this area it usually is T&G pine
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 05-14-2013, 01:23 PM   #7
kwikfishron's Avatar
Rewards Points: 1,024
I've attached to trusses many times without issue. Of coarse the NW Coast doesn't see huge seasonal changes so I don't know about anywhere else.
I've always called it V-groove T&G. If you do go with it stick to the single exposure, the double is just to wide and would be more prone splits and checks.
Never used the pine out West, not with all of them big Red Cedar Trees in the hood.
kwikfishron is online now   Reply With Quote
Old 05-14-2013, 01:40 PM   #8
Rewards Points: 626
Originally Posted by Seattle2k View Post
That is also called car decking
Old 05-14-2013, 05:55 PM   #9
Old School
Willie T's Avatar
Interestingly enough, some railway companies starting installing stamped steel sheets with the same look on their cars in the 1960's. And today, it can be purchased as either wood (it's really just T&G), metal, or vinyl.
Willie T
Pine Carsiding questions HandyBiker Carpentry 3 04-19-2011 10:12 PM
carsiding ceiling ClayFraz3 Remodeling 4 12-19-2010 11:16 AM
carsiding doesn't meet in corners thibadop Carpentry 5 03-27-2010 01:16 PM
Does T&G Carsiding Meet Code? cibula11 Building & Construction 2 01-19-2010 08:51 PM
Attaching Carsiding cibula11 Carpentry 6 02-12-2007 01:16 PM
