Carriage Bolts And Wood - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-01-2009, 07:57 PM   #1
Carriage bolts and wood
Am I just a serious amateur or what? I am building bunk beds and plan to use carriage bolts. Do I just pound the square into the wood and hope it bites good? I guess I could just try it on some scraps. I'm using regular SPF lumber.
dhag is offline   Reply With Quote
Old 03-01-2009, 08:03 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
with the proper hole for that particular bolt, it will start to grab when the bolt is being pulled in by the nut being tightened.
Old 03-01-2009, 08:49 PM   #3
When I built my picnic table I bought a washer that fits the square head of the bolt. It then had 2 cut outs that were perpendicular to the washer & would stick into the wood. This would stop the bolt from turning - but not if it was really soft wood or you applied too much force
Sort of like this
Old 03-02-2009, 08:51 AM   #4
47_47's Avatar
Rewards Points: 44
Just tap it into the hole to start seating the square, the nut will draw it in.
Added: For bunk beds, use acorn nuts or a forsner bit to make a recess for a regular nut, flat and lock washer.
47_47 is online now   Reply With Quote
Old 03-02-2009, 02:30 PM   #5
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,186
Answer
Scuba Dave has posted your answer. I would use them as recomended. Hey Scuba Dave, got a link to where to buy them? Dorf Dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 03-02-2009, 02:50 PM   #6
I've always bought them at Home Depot - big box DIY store
On my picnic table I also recessed the nuts on the opposite side
I bought bolts that ended up flush with the wood
Nice clean look, but I was dealing with 2x so I had room to recess
Old 03-02-2009, 03:02 PM   #7
47_47's Avatar
Rewards Points: 44
DD
http://www.mcfeelys.com/torque-washers
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 12:05 PM
Wood Glue Issue gp1200r Carpentry 4 02-20-2008 12:56 PM
Tricky Wood Stove Question Mosca General DIY Discussions 7 12-22-2005 01:42 AM
How to attach wood to masonry? pgd Building & Construction 2 11-30-2005 06:59 PM
Question About Bolting Wood Together for a Loft ArcticRSXS Building & Construction 15 09-16-2005 05:42 PM
