Carpet Consideration When Building A Straight Staircase - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-08-2013, 12:03 PM   #1
Carpet consideration when building a straight staircase
I have a hypothetical question about carpet consideration when building a staircase that I cannot seem to figure out. I am going to demo the current basement staircase and relocate another one 180 degrees from a different opening. My question though, is do I take into account 3/4 in for padding and carpet when measuring and cutting my risers? So that if I were to estimate a final 7 1/2" rise after carpet install, then I should cut my risers to 8 1/4"? If I used a 7 1/2" riser height for initial cut, then after carpet/padding is installed wouldnt it give me a 6 3/4" rise?
This seems self-explanatory but I'm not really sure. Thanks
Gnex81 is offline   Reply With Quote
Old 11-08-2013, 07:39 PM   #2
43 years in construction
Arkitexas's Avatar
Think about it for a minute. With any given riser, if you add 3/4" to the riser height by carpeting the upper tread, you are also decreasing 3/4" from the riser height due to the carpet on the tread below. The resultant riser dimension does not change. So, if you want a 7.5" riser after the carpet is installed, build the wood to the same 7.5".
Arkitexas is offline   Reply With Quote
Old 11-08-2013, 08:06 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
I agree with Arkitexas, the only two risers that would change would be the first at the bottom and the last one at the top. You would need to make the bottom riser and the top riser the thickness of the carpet and pad less. The only way all the risers would stay the same is if there was carpet on the bottom floor and the top floor.
Example of this would be to lay a piece of 3/4 board on each of the treads and see the difference in height first hand.
I always allowed a 1/2 inch for carpet and pad. Another thing is be aware of how slick carpet can be on stairs.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Cost to Drywall hang/finish...please read, good explanation Firehawk734 Remodeling 64 12-12-2014 05:15 PM
Building a staircase moneymgmt Building & Construction 10 11-18-2013 08:11 PM
Carpet Flooding and Replacement airjay81 Flooring 1 05-08-2012 01:00 PM
Quarter Round with New Carpet ryanb4614 Flooring 4 11-21-2011 10:20 AM
Finishing Basement, carpet install order? tigerbalm2424 Flooring 33 07-24-2008 09:35 AM
