Carpentry Or Roofing? - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-19-2009, 12:15 PM   #1
Carpentry or roofing?
I have a house with a flat top roof and I'm concerned about the boards that create the overhang from the edge of the roof. They appear to be 1X12 boards and run the entire perimeter of the roof. Some of them are warped and starting to pull away from the underlying structure. I would like to get them replaced before they create serious moisture damage and or compromise the actual roofing surface. Can anyone tell me the proper material to use for this job and the basics for attacking the problem? Thanks!!!
bigdinla is offline   Reply With Quote
Old 11-19-2009, 12:42 PM   #2
Remodeling Contractor
I would replace these with azek. This way it will be maintenance free forever. A carpenter would be the one to do the work and install the new flashing over the top edge of the new fascia
Old 11-19-2009, 01:43 PM   #3
OK, I give up. What's azek? Thanks again, Duffy
Old 11-19-2009, 03:06 PM   #4
A composite board that is workable like wood, but will not rot, need painting but can be painted and insect resistant.
Old 11-19-2009, 05:28 PM   #5
Sounds great
Do you know who might sell this miracle product in the Los Angeles/Long Beach area? Sounds great. You da man. Duffy
Old 11-19-2009, 09:20 PM   #6
You can use treated wood, or regular wood as long as it is capped.If you can remove the old ones with out ruining the drip edge then you simple slide them up under it. Treated wood has to be covered to be caped due to a chemical reaction. Make sure your crown of your wood is facing in when you attach them.
harby is offline   Reply With Quote
Old 11-19-2009, 09:40 PM   #7
pressure treated lumber would not be a good idea. It warps and moves too much and will never look good. To find local dealers for the composites use this site. http://www.azek.com/where-to-buy.html
Old 11-20-2009, 10:45 AM   #8
Thanks Harby, but this azek stuff sounds like the move. Comes with a 25 year guarantee. Pretty great. Appreciate your input! Duffy
Old 11-20-2009, 10:47 AM   #9
Thanks Again Bob!
One of them is right down the street. Duffy
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 06:10 AM
Rolled Roofing Leaking and Leaking DIYNewbee Roofing/Siding 9 12-13-2009 10:46 PM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 07:09 AM
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing/Siding 9 09-13-2009 06:32 PM
Roofing Company Refuses to Quote for ... Dodah Roofing/Siding 11 06-03-2009 07:17 PM
