Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-21-2013, 11:31 AM   #1
Car port
I'm building a carport and had a question about 2x6 span. It's 13' from pole to pole, will 2x6's be adequate support for that span? The only weight it will be holding is the plywood and roll out 2 ply roofing. Thx
patsfan1 is offline   Reply With Quote
Old 01-21-2013, 12:39 PM   #2
STAFF
BigJim's Avatar
Car port
Is this a shed roof or gable roof, where are you located, how about snow loads?
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 01-21-2013, 12:45 PM   #3
Car port
It's basically just an open carport coming off off a house. Mid Texas, snow isn't really an issue. So it's really just 2x6 cover that comes off the house with a 12-2 pitch.
Old 01-21-2013, 01:03 PM   #4
GBrackins's Avatar
Car port
are you using the 2x6 for rafters or a beam to support the rafters?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is online now   Reply With Quote
Old 01-21-2013, 01:25 PM   #5
Car port
As the rafters
Old 01-21-2013, 01:32 PM   #6
Car port
I suppose I could also put some angles supports coming off of the poles to add additional support as well.
Old 01-21-2013, 01:48 PM   #7
GBrackins's Avatar
Car port
you'd need to call your local building department to determine the minimum live load for your roof. then use the appropriate span table. these tables are as found in the 2009 International Residential Code.
Gary
Old 01-21-2013, 01:49 PM   #8
GBrackins's Avatar
Car port
typically you'd have beams that support the rafters and columns that support the beams
Gary
Old 01-21-2013, 01:56 PM   #9
Car port
Thankyou
Water Staining Around High Velocity AC Port Nhfixit HVAC 4 12-02-2012 11:46 AM
R134A Port on GE Monogram Refrigerator benjamincall Appliances 6 06-13-2012 01:12 PM
Lennox 80MGF3-75A Inducer Port Clogged jay235 HVAC 3 04-25-2012 07:00 PM
Furnace port, and combustion chamber crack question. cjf1980 HVAC 0 07-27-2009 10:23 PM
