Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-18-2012, 11:11 AM   #1
cap on knee wall?
I am doing some work to my basement and am going to be installing a cap amd trim on thesurrounding knee/frost wall. the problem is whoever did the framing and sheetrock to finish the basement did a poor job and the top ledge is pretty wavy making it difficult to get the cap boards lined up. my question is what options are there to get this to work? I tried shims but that is such a pain unlike windows and doors. for that matter i have half a mind to cut the ends at 45 angles so i can adjust the boards but then i worry about the boards pulling up later on. i wish i had the time and money to rip the sheetrock out bit i dont.
vikingextreme93 is offline   Reply With Quote
Old 07-18-2012, 11:24 AM   #2
cap on knee wall?
Okay. When you say wavy, do you mean up and down wavy, side to side wavy, or both? Also, how wide is the top of the ledge?
CopperClad is offline   Reply With Quote
Old 07-18-2012, 11:48 AM   #3
cap on knee wall?
is wavy up and down like they did not do a good job measuring and just slapped on sheetrock with no top plate....the more i think about it the more i feel i may just be best off opening it up...but then i worry what i may find. Off the top of my head the wall is a bit over 6 inches deep. i should also elaborat that cutting 45 angles i meant so they overlap which could allow me to fill and sand as needed a little
Old 07-18-2012, 12:07 PM   #4
Retired Cabinetmaker
woody4249's Avatar
cap on knee wall?
A picture is worth a thousand words. Post some photos and we will be able to advise you better.
There is a solution to this problem
Mike
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
The Following 2 Users Say Thank You to woody4249 For This Useful Post:
mae-ling (07-19-2012), PaliBob (07-18-2012)
Attaching metal knee wall to CMU wall. Bass283 Building & Construction 4 06-11-2012 12:17 PM
knee wall attic access doors WillK Building & Construction 4 12-01-2010 07:32 AM
How to prevent mold in knee wall cabinet dressers cxcarl Building & Construction 1 03-13-2010 08:01 PM
Framing stair knee wall... bparise Carpentry 6 11-14-2009 01:03 AM
Building knee wall in basement, best approach? RyanD Building & Construction 6 07-04-2009 02:07 PM
