Cantilever - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-17-2011, 11:10 AM   #1
Cantilever
What's the most u can cantilever over second story using 2x10x10
tootsie007 is offline   Reply With Quote
Old 01-17-2011, 05:02 PM   #2
Registered User
Rewards Points: 526
A bearing wall or a shear wall can only be offset the joist thickness, 9-1/4” to the face, in your case; Fig. 67, as it says--- check locally with your Building Department; http://docs.google.com/viewer?a=v&q=...Ayb-Iq_X-tT_ew
Anything more needs to be approved by them.
Gary
Old 01-23-2011, 09:05 PM   #3
Rewards Points: 212
the maximum for 2x12 is 4 feet and you need 2 parts in to one part out so i would definitely not go over 3 feet and the two end need to be doubled if you were out 3 feet you would have six feet inside the building glued and nailed to the other joists
bluebird5 is offline   Reply With Quote
Old 01-23-2011, 09:09 PM   #4
Rewards Points: 212
that is 16 on center not greater 12 would be even better
Old 01-23-2011, 09:56 PM   #5
2 to 1 only works to a certain point. You need to have an engineer look at it. Best couple hundred bucks youll spend. Lots of things affect a cantilever. The roof, what the room purpose is, floor covering, one story or two. Ive framed for a while and I dont even try and guess this stuff. Long term problems arnt worth it.
ubenhad4 is offline   Reply With Quote
Old 01-23-2011, 10:01 PM   #6
Rewards Points: 212
you are right i was just giving some general info and it seems like anyone doing this would not be a first timer its a second story so there is only a ceiling and roof load usless its a 3 story house
Old 01-23-2011, 10:08 PM   #7
Im always a bit careful in here. Dont want anyone canting a floor four ft then throwing a 30 ft ridge up that bears on that cant with a door out to there deck that's 20 X20 hanging of that cant. Structural stuff and DIY sometimes are really scary. Ive worked on some scary fixes.
Old 01-23-2011, 10:17 PM   #8
Rewards Points: 212
I agree 100%
The Following User Says Thank You to bluebird5 For This Useful Post:
ubenhad4 (01-23-2011)
Old 01-23-2011, 10:47 PM   #9
Registered User
Rewards Points: 526
18"-29" max.; http://publicecodes.citation.com/ico...002_par019.htm
Gary
Old 01-23-2011, 11:04 PM   #10
Rewards Points: 212
http://www.nibs.org/client/assets/fi...pter4final.pdf
Old 01-23-2011, 11:40 PM   #11
Registered User
Rewards Points: 526
http://www.fema.gov/library/viewRecord.do?id=2103
I have that one also (232), dated 2006. It has been replaced with the 2009; (first one listed); http://www.google.com/search?client=...=Google+Search
Which does not cover cantilevers (or maybe I missed it) which is why I quoted the most current IRC 2009, depends on which Code the OP is under….. Check with your local B.D, as mentioned.
Gary
Old 01-24-2011, 02:22 PM   #12
I always go back at least three to one but there are many circumstances that can change that. purpose loads and counter balances etc. We need more info SVP
masterofall is offline   Reply With Quote
Insulate existing cantilever flamingomtn Building & Construction 2 09-18-2010 09:29 PM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK Remodeling 7 11-04-2009 08:10 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK HVAC 5 11-01-2009 08:15 PM
Attaching deck ledger to cantilever ram80ran Building & Construction 13 04-18-2009 12:29 PM
Ranch to cantilever 2 story? Badfish740 Remodeling 3 01-04-2009 04:14 PM
