Can't Stand The Kitchen Being A Hallway Any Longer! - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-24-2012, 09:11 PM   #1
Can't stand the kitchen being a hallway any longer!
The stairs that lead to the basement in our home, start from the kitchen, going down 3 steps to a landing. From the landing, there are 8 steps down to the basement. The centre beam of the house runs parallel to the run of 8 stairs, on the opposite side of the kitchen. Is it possible to otherwise support the house, to make it possible for the 3 steps to go up into the living room rather than the kitchen?
Sandicane is offline   Reply With Quote
Old 01-24-2012, 09:16 PM   #2
Too Short? Cut it Again!
Could you post pictures or a drawing/sketch (Sweet Home 3D is nice, open source software and it is free)? Where is the living room in relation to the beam and the kitchen?
Old 01-24-2012, 10:20 PM   #3
I've taken 2 pictures, however, it would appear they are too large to post. I'll try to make a drawing and post it. Thanks, Sandi
Old 01-25-2012, 02:01 AM   #4
Retired carpenter
From your description, what you call the center beam of the house must be actually a bearing wall along the center of the house cutting the span of the ceiling joists in half, and that bearing wall already has an opening to go from the kitchen to the stairs. That would mean that the other wall you want to cut into to get to the living room is actually (possibly) two bearing walls: one supporting the floor joists under the living room (the one you would have to cut on top for your three steps in the other direction) and one possibly supporting also the ceiling joists (the one you would have to cut on the bottom to get the headroom you need).
Too much work, if you ask me, when you already have working stairs. Easier to set rules of passage through the kitchen!
abracaboom is offline   Reply With Quote
Old 01-25-2012, 04:49 AM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
This may help.
How to resize photos to post them here.
The Following User Says Thank You to Blondesense For This Useful Post:
Willie T (01-25-2012)
Old 01-25-2012, 12:44 PM   #6
Old School
Willie T's Avatar
If you can get the top three steps to come up right at the edge of the beam, (or shorter), this sounds like a snap (more or less). But you probably cannot cut that beam at all if you need more room to get the steps by.
Willie T
Yet another Kitchen Sub-panel Post...Sorry tpagel Electrical 4 03-19-2011 10:54 PM
My kitchen update project, wood floors to start! 240sx4u Project Showcase 21 02-26-2011 09:09 AM
Kitchen question laur15 General DIY Discussions 3 11-24-2009 01:30 PM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 09:31 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
