Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-05-2011, 08:39 PM   #1
Cant remove old door knob...?
Hello everyone,
I am having a difficult time trying to remove an old door knob. After removing four screws is still does not budge. Ive tried to go at it with pliers but still cant get the thing off. Here are some pictures,
Front knob, I tried to remove the metal plate where there appears to be a hole underneath. Im not sure what this hole is for.
Rear of the knob where i removed the two screws.
Side plate where i removed two screws.
I removed a cap the door knob had and this is what it looked like inside.
Any feedback would be greatly appreciated.
toicy4ya is offline   Reply With Quote
Old 09-05-2011, 08:56 PM   #2
Super Moderator
That's a square shaft set---there should be a set screw in the side if the door knob ---
oh'mike is online now   Reply With Quote
Old 09-06-2011, 05:57 AM   #3
I looked all around the side of the knob, I don't see any screws.
Old 09-06-2011, 08:24 AM   #4
Super Moderator
BUMP--
Old 09-06-2011, 08:33 AM   #5
Military Mom of 4
Snav's Avatar
Any luck, yet?
If it went it it'll come out - looks like it's just so painted over and rusted into place it's being stubborn. Coat that sucker with wd40 . . .personally, though, Id' take the lazy easy more fun route and just sledge that sucker out using the squared post a tapping point.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 09-06-2011, 08:33 AM   #6
It should be on the knob shaft, close to the door, facing the floor.
Ron
B. Franklin 1759
Old 09-06-2011, 09:09 AM   #7
gravity always wins
Hacksaw the knob off. At least you won't destroy the door that way.
Old 09-06-2011, 10:53 AM   #8
I actually busted the knob trying to remove it so it turns all around. However I can't see any screws or pin holes. I'm trying to avoid going at it with a hacksaw and leave it as a last alternative. I know that will be a pain.
Old 09-06-2011, 11:17 AM   #9
STAFF
BigJim's Avatar
Some of those old knobs were spring loaded, will the knob push in? If it will maybe there is a clip on the square stock.
Have you tried taking the two screws out on the other side of the door yet?
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 09-06-2011, 03:13 PM   #10
The knob doesn't push in. I've taken out all the screws that I see, it still will not break loose.
Old 09-06-2011, 03:27 PM   #11
Mod
kwikfishron's Avatar
I agree with Mike (post #2).
Have you looked under the knob. There should be a small hole with a tiny screw recessed inside.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 09-06-2011, 07:52 PM   #12
Thanks, i was able to pry it loose using a pair of pliers.
The Following User Says Thank You to toicy4ya For This Useful Post:
oh'mike (09-06-2011)
How do you remove a wood stove and bricks from living room? SimpleJack Remodeling 13 08-28-2011 02:26 PM
Wrong Sealant used on Unfinished Ceramic Tile... how to remove?! flipjarg Flooring 3 02-15-2010 10:09 PM
best way to remove areca palm root system Dus Landscaping & Lawn Care 0 01-23-2010 10:40 AM
Frigidaire/can't remove front water/ice dispenser tigerfan44 Appliances 0 12-17-2009 11:45 PM
How can I remove my gutter / apron with out pulling the first row of shingels wamyers92 Roofing/Siding 3 07-02-2008 03:10 AM
