Cant Figure Out What Angle To Cut Crown Moulding - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-17-2013, 04:48 PM   #16
Too Short? Cut it Again!
There are some decent online and smartphone crown molding angle calculators. Most expensive for Android was $2.99.
Old 05-12-2013, 07:52 PM   #17
Rewards Points: 1,062
Whew!! Man, im done! Geez, talk about a pain in the neck- crown is a pain. But, I practiced on a few cheap boards, and firgured out the angles. Yup- you gotta learn that the crown will have to be cut upside down for some angles on the mitre saw. But ALWAYs on the fence/base, not flat down. Flat works only for the sister cut for a running board. Oh- no need for the confusing double mitre - I dont understand why they even bother with that. I got it done without it.
The This Old House video from JOED didnt even bother with that.........Inside corner, and outside corner, plus a running sister cut. Yes, I appreciate that some angles can get really hairy- Im glad I didnt have any this time......
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 05-14-2013, 11:06 PM   #18
Use crown stops and a quality saw and you cant go wrong. You can lay the crown flat, but you need to know the exact spring angle of the crown and you will never be able to get it right on the saw. Also 45 does not always work!
ubcguy89 is offline   Reply With Quote
The Following User Says Thank You to ubcguy89 For This Useful Post:
noquacks (05-16-2013)
Old 05-16-2013, 07:10 AM   #19
Thanks, UB. I know a little knowledge can be dangerous (my quote below). Im not an expert on crown yet...LOL. But I do know this is not like putting together engine parts on an airplane. A 45 angle is a 45. Yes, if I extend the angle out 10 feet, it may correct to 45.2 or so, but the plane wont fall out of the saky.
Old 05-16-2013, 07:25 AM   #20
Rewards Points: 150
How about some pics of the finished product?????!!!!
stradt03 is offline   Reply With Quote
Old 05-16-2013, 09:07 AM   #21
Rewards Points: 89
I am no "pro" but can hang crown. On my latest project (where I will be doing the entire house) I bought poplar for the crown from a mill (1/2 the price of finger jointed primed pine..... I also had them run some MDF for "scraps".
No angles in my house are exactly 90/45. I made 1' pairs of 44,45,46 and the same for the 22,23,24 etc... I went around the room with my bucket of pairs (tied together) and marked every corner with the matching pair and wrote it on the wall (where the crown would hide it). Also when the dummy pair is tight hold it and mark the wall on the top and bottom edge of the sheetrock with a pencil so when you hang it your can put it in that exact spot.
I also use a Bosch laser measuring device, wife bought it for me for X-mas. This eliminates the need for her to hold the tape measure. It is dead nuts every time (to a 32nd). Sorry for the crappy phone pic of the crown.
Cant figure out what angle to cut crown moulding-bosch.jpg   Cant figure out what angle to cut crown moulding-photo.jpg
tjfslaughter is offline   Reply With Quote
Old 05-16-2013, 09:22 AM   #22
Rewards Points: 150
I use a laser measuring device for doing my crown also. Makes those long runs super easy to measure.
Old 05-16-2013, 09:59 AM   #23
Rewards Points: 89
I think it is one of the best tools I have for Crown, it removes any "droop" in the tape. I found that I had to cut the pencil line for it to work. I would mark the crown and if I left the line on the crown it was a 1/2 kerf to large....
I also used it when caculating my Sheetrock, insulation, wire, etc... Anywere you need a second hand with a tape measure it works.
Old 05-16-2013, 10:17 AM   #24
JOATMON
ddawg16's Avatar
Rewards Points: 1,124
I have no trouble what so ever cutting crown molding. Comes out perfect every time.
Oh.....and I have some ocean front property for sale in NM.
Anyone who says that don't have issues.....well, has never done in crown molding.
It's a lot easier if your going to paint it....that is what calk is for.....but stained? Yep...buy extra.
Slaughter...nice job....but only one comment....and maybe it's a personal preference....I would have finished the ceiling and walls first...and then put up the molding.
Old 05-16-2013, 10:29 AM   #25
Rewards Points: 89
Thanks for the comment, the spackle guy I have can only work at my house on weekends. He is very busy with Hurricane work in south Jersey. He finished the cieling/wall joints first so I could hang the crown. Its paint grade so when I spray prime later this week it all gets done in one shot.
Old 05-16-2013, 10:56 AM   #26
JOATMON
ddawg16's Avatar
In that case...I would run a thin bead of paintable calk along each edge prior to primer.....then, when it's done, it will look perfect.
Old 05-16-2013, 11:01 AM   #27
Rewards Points: 89
Thats the plan. The spakle guy floated compount into the larger gaps along the wall and ceiling.
Old 05-16-2013, 07:40 PM   #28
Registered User
Rewards Points: 5,216
noquacks;" But I do know this is not like putting together engine parts on an airplane."--- yet make sure to install it right-side-up; ogee-- up and Scotia (busy part)-- down, otherwise it just looks wrong ( good news; not to everyone); http://www.altereagle.com/How_to_install.html
Use a helper stick to mark the wall or to set the angle in place;http://www.finehomebuilding.com/how-...echniques.aspx
If a 12" saw, the simplest way:http://americanwoodworker.com/blogs/...n-molding.aspx
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
noquacks (05-19-2013)
Old 05-16-2013, 08:54 PM   #29
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
what gary just posted is the best way to hold the crown in place if your cutting crown in the sprung position.
as for getting your angles right the best tool to use is a starrett angle finder.. just check the corner first with it and your already within 1/2 a degree of the cut.. this way your not fussing with angles on the saw several times to get a joint tight . .
scarf joints also require fussing over, you will have to tweak your cuts no matter how good you are.. slight deviations in the wall or ceiling will throw off how the piece of crown sits which can cause a joint to be open on one point.. gluing the joint and nailing it is imperitive.. then sand it flush
now if your installing stain grade crown you abslutely have to have a deadly accurate saw that has no blade deflection at all. there is no room for error with stain grade. if its not tight when you install it as soon as the heating season starts the joint will open up even more as the wood dries out
woodworkbykirk is offline   Reply With Quote
Old 05-19-2013, 07:35 AM   #30
Thaks, people, for the replies/advice. Man, hope I never have to do this again....LOL
160 Degree Crown Moulding Install natethegreat Carpentry 6 09-04-2012 12:09 AM
Crown Moulding Paint Peeling ryanb4614 Painting 6 01-23-2012 10:15 AM
Cardboard Crown Moulding rosco Carpentry 33 07-09-2010 02:54 AM
crown moulding painting WorkOnIt Painting 3 06-18-2007 11:56 AM
acute crown angle virginia rob Carpentry 1 05-28-2007 03:12 PM
