Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-19-2006, 08:14 AM   #1
cannot make cabinets flush with wall
Hi
Just bought my first home and am trying to put up some melamine cabinets into a plasterwall and a stud. I purchased standard wood screws long enough to do the job and thought it would be an easy job to drill them into place.
However whenever screw them in place the cabinet comes away from the wall. As i continue to screw in the screw begins to push through the melamine but doesnt bring cabinet any closer to the wall. With some screws i cannot push them in further and am stripping the head of the screw.
I was thinking that pre drilling the hole would work and that perhaps the stud i was drilling into was too hard, but even pre drilling it didnt work... unless i didnt use a large enough drill bit (i used one a couple of sizes smaller than the screw).
Am i on the right track with pre drilling? Should i use something else other than wood screws straight into the melamine/plasterwall?
Any advice for a newbie?
thanks
Barcoo
barcoo is offline   Reply With Quote
Old 07-19-2006, 11:10 AM   #2
Remodeler
MinConst's Avatar
When you pre drill the holes, as you should. Choose a bit that matches the shaft size of the screw (smaller than the thread size). Drill into the stud through the cabinet. Then drill a larger hole through the cabinet with a larger bit that will allow the screw to spin freely thought the cabinet. This will stop the cab from coming off the wall and will allow the screw to act as a clamp.
If your walls are plumb and flat there should not be a problem. If the walls are not flat you will need to shim the cab to lay against the wall.
Also you should be using cabinet screws that have a built in washer on them Not standard wood screws. The washer stops the screw from driving into the cabinet. Also gives a more finished look. Be sure you are hitting a stud and not just the lath.
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 07-20-2006, 06:28 PM   #3
Hi
Thanks for the advice - it worked a treat and the cabinets are now flush and holding firm.
Barcoo
Old 07-20-2006, 11:58 PM   #4
Remodeler
MinConst's Avatar
Glad I could help.
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
Hanging cabinets on cinder block wall ponchoman1 Remodeling 2 04-25-2006 10:34 PM
