Can You Use Only Glue For Small Wood Items? - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-21-2011, 08:29 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
Can you use only glue for small wood items?
If I was to build a small box-like item using 1x6 planks, say, 2 feet by 5 inches by 5 inches, can I get away with just glue, or do I need nails as well? What kind of nails (or screws) are best for something like this? Can I just use deck screws or will that cause the wood to crack? (I would predrill).
I guess if I want to get fancy I could use dovetails, too.
Old 05-21-2011, 08:38 PM   #2
Learning by Doing
Leah Frances's Avatar
It sort of depends on what you want to do with it.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-21-2011, 08:39 PM   #3
If you are talking about but joints on the corner you will need a fastener . Glue doesn't provide much hold on end grain. If you are mitering the corners glue will hold but fasteners may still be needed. Pocket hole screws are good, biscuits are good, miller dowels are good, Or you could counter sink and use screws and plugs.
hayewe farm is offline   Reply With Quote
Old 05-21-2011, 08:39 PM   #4
Old School
Willie T's Avatar
Yes, good glue (I use 2P-10) is usually sufficient if you apply and clamp it properly.
Willie T
Old 05-21-2011, 08:46 PM   #5
the Musigician
DangerMouse's Avatar
Pre-drill, glue and screw and you should be fine.
DM
Old 05-21-2011, 08:53 PM   #6
Wire Chewer
Rewards Points: 138
Was thinking of using weldbond, is that stuff decent for wood? This is not something that really needs to be that strong but still needs to hold together and not eventually fall apart. Basically it will hold 2 4 gang boxes (they will be screwed in) and have plates on them. Building a 16 outlet power bar to replace my 3 power bars, so I can tidy up under the desk a bit.
I will most likely mitre the joints to give more glue surface area. I was also thinking biscuits or or dowels, is that something common I'd find at the hardware store? Guessing there is a special drill bit to make the right size/depth hole? I may go that route.
Old 05-21-2011, 08:56 PM   #7
the Musigician
I'd just rabbet the edges and glue/screw it together. It'd be more than strong enough.
That'd be the easiest/fastest way.
DM
Old 05-21-2011, 09:01 PM   #8
Old School
Willie T's Avatar
Just to give you an example of the power of glue, the wings of my airplane don't have one nail or screw in the 26 feet of their span. Just epoxy. It really does work, that's why you won't find anything but glue in the frames of your better chairs.
Willie T
Old 05-21-2011, 09:20 PM   #9
DIY staff
Rewards Points: 7,174
Tight Bond wood glue--the joined surfaces will be stronger than the wood itself.
kwikfishron (05-22-2011)
Old 05-21-2011, 10:01 PM   #10
Wire Chewer
Rewards Points: 138
Wow that's some serious stuff!
Old 05-22-2011, 05:14 PM   #11
Too Short? Cut it Again!
I am a Guerilla Glue fan but would still use a fastener. Good clamps in either situation.
Why the opposition to one or two by the way? And is this box thing indoors or out?
Old 05-22-2011, 06:24 PM   #12
Wire Chewer
Rewards Points: 138
I ended up using screws, I was not taking into account that I'd have to wait for the glue to dry before moving on, or things would get tricky. I am screwing everything together first, then afterwards I'll unscrew, sand some edges I cut crooked, and when I put it back together I'll glue and the screws will also act as the clamps. Once it's back together I'll do a final sanding to get everything lined up, and then paint. I don't have a very good work environment so it's a bit tricky. I want to build a shop but that's down the road.
Ran out of screws, I'll have to go buy more tomorrow. I hope they make 1x1's because I will need one to complete it. If I had a table saw I could cut a 1x2 but the thought of doing it with the circular saw does not sound like fun, or safe. :p
And this is definitely for indoors, being an electrical device that is not weather sealed.
Old 05-22-2011, 07:03 PM   #13
Learning by Doing
You still haven't told us what you're making.....
Old 05-22-2011, 07:23 PM   #14
Wire Chewer
Rewards Points: 138
A 16 outlet power bar.
That will replace my 3 daisy chained ones under my computer desk. Basically 2 4 gang boxes with a wood enclosure around it. It will have two power cords, so one side will be UPS protected and the other side will only be surge protected.
I should have enough plugs with that.
Old 05-22-2011, 07:37 PM   #15
Sparky
Rewards Points: 510
he's building a something to plug a lot of somethings into one outlet.
Techy is offline   Reply With Quote
Basement Decorative Wood Wall Cover popping up tk3000 Building & Construction 8 10-29-2010 12:17 PM
Removing old glue from wood flooring Patsyjo Flooring 0 10-24-2010 12:24 PM
Glue and staple engineered wood on stair treads? cej22 Flooring 1 09-23-2009 10:13 AM
Which Is Better - Wood Glue OR Liquid Nails? JackOfAllTrades Carpentry 10 09-16-2009 02:02 PM
Removing floor tile glue from a wood floor mrmordun Flooring 2 09-03-2008 09:41 PM
