Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-21-2011, 02:11 PM   #1
Can these studs be removed?
Hi guys and thank you in advance for the help. I am in the process of remodeling my shower and would like to expand it into the "wasted space" area to the left (see photo). Are these studs supporting anything or are they just part of the shower framing? 2nd floor master bath.
Jontrax is offline   Reply With Quote
Old 10-21-2011, 04:34 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
they look like they might be able to be removed, but without seeing the framing of the roofline its hard to actually say..
looks as if a tub unit was there before which needed a proper surface to fasten both it and the drywall too while allowing enough space for a inside corner to get taped
woodworkbykirk is offline   Reply With Quote
Old 10-21-2011, 04:51 PM   #3
Looks to be a partition wall as it's 2 feet from the exterior wall.
What's above this wall, the roof rafters and attic space?
Ron
B. Franklin 1759
Old 10-21-2011, 08:56 PM   #4
Yes, the attic is above.
Old 10-21-2011, 09:01 PM   #5
In my opinion, you can take the wall out.
Ron
B. Franklin 1759
1 or 2 jack studs? NCgranny Building & Construction 8 03-22-2010 11:17 AM
How to repair rotted joists and studs? Snav Building & Construction 5 02-24-2010 11:35 PM
Help with straightening studs before drywalling genEus Carpentry 3 08-29-2008 03:12 PM
How difficult is it to learn to use metal studs? YerDugliness Building & Construction 7 08-18-2008 07:59 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 05:16 PM
