Can Someone Tell Me What This Is? - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-23-2015, 08:19 PM   #1
Rewards Points: 16
Can someone tell me what this is?
Are these joists? Don't look like normal joists to me but yet they seem to have subflooring attached to them.
DKR99 is offline   Reply With Quote
Old 11-23-2015, 09:25 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 3,478
Engineered trusses.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following 2 Users Say Thank You to rjniles For This Useful Post:
de-nagorg (11-23-2015), gregzoll (11-23-2015)
Old 11-23-2015, 09:53 PM   #3
Retired from the grind
gregzoll's Avatar
Rewards Points: 5,864
They have been the norm for over 30 years. That is actually the roof most likely, not another floor.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 11-23-2015, 10:06 PM   #4
Rewards Points: 16
That's the top of the first floor bottom of the second
Old 11-23-2015, 11:10 PM   #5
simeltzer's Avatar
Rewards Points: 44
They are usually pressed together with gusset plates
simeltzer is offline   Reply With Quote
Old 11-23-2015, 11:21 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 6,096
Yep....engineered joists. I looked into using them on my addition....
From what I found....very stiff....but they take up more vertical space.
One of their big advantages....you have lots of room to run venting through. Something that is difficult with traditional sawn lumber joists.
The Following User Says Thank You to ddawg16 For This Useful Post:
Windows on Wash (11-23-2015)
Old 11-23-2015, 11:35 PM   #7
General contractor/carpen
Californiadecks's Avatar
Rewards Points: 38
Another advantage to those are for spans. You can get a large clear span with them. Depending on the length and wieght calculations they often times come cambered as well.
Hillary for prison, 2016
Californiadecks is online now   Reply With Quote
The Following User Says Thank You to Californiadecks For This Useful Post:
Old 11-24-2015, 01:53 AM   #8
gregzoll's Avatar
Originally Posted by ddawg16 View Post
Yep....engineered joists. I looked into using them on my addition. From what I found....very stiff....but they take up more vertical space. One of their big advantages....you have lots of room to run venting through. Something that is difficult with traditional sawn lumber joists.
It makes it a lot easier to place everything up inside the truss, instead of having to drop the ceiling lower to run Cold Air Returns, etc. You have to compensate for the difference in height of course, when using them.
Old 11-24-2015, 08:03 PM   #9
Rewards Points: 2,174
Look closer and you'll see the gusset spike plates. Ron
ront02769 is offline   Reply With Quote
Old 11-24-2015, 09:55 PM   #10
Rewards Points: 228
My father speced these back in '77 when he built his house. I always said if I ever built a house I would use them, no question about it. No columns in the basement no load bearing walls in the whole house. And as has been said the mechanical's are a snap. Cost a little more, but there is some labor savings and since you save on beams and columns it almost washes out price wise. Also finishing the basement was easy, since all the mechanical's fit up in there, no drop ceilings you can do "normal" drywall much easier.
KC_Jones is offline   Reply With Quote
The Following User Says Thank You to KC_Jones For This Useful Post:
gregzoll (11-25-2015)
Old 11-25-2015, 06:35 AM   #11
Rewards Points: 82
I find slight humor in the fact that in the picture at top left it says joist right on the wood...
barnabas131 is offline   Reply With Quote
The Following User Says Thank You to barnabas131 For This Useful Post:
Old 11-25-2015, 07:13 AM   #12
Rewards Points: 700
I see finger joints.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Windows on Wash (11-25-2015)
Old 11-25-2015, 11:08 AM   #13
47_47's Avatar
Rewards Points: 106
Always called them bar joists.
47_47 is offline   Reply With Quote
Old 11-26-2015, 12:22 PM   #14
Rewards Points: 12
They're called "open web trusses". Very common, strong, easier to run plumbing and electrical thought, somewhat easy to tie an exterior deck into, etc.
StreakersQB is offline   Reply With Quote
The Following User Says Thank You to StreakersQB For This Useful Post:
gregzoll (11-26-2015)
Old 11-26-2015, 12:24 PM   #15
Rewards Points: 12
The fact that it's OSB sheeted on top says it's a floor.
