Can I Use This For Crown Moulding - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-28-2013, 10:30 AM   #1
Rewards Points: 878
Can i use this for crown moulding
Just bought this air compressor as I got it for $39.00 with coupon. I just really bought it just to have it just in case but I actually want to do crown moulding in a small room....15x16. Can this compressor be used for that? Which nail gun would I get? I put link to them below. Thanks
Would the 23 gauge pin nailer work? I don't want to spend a lot as I may only use this 3-4 other times?
http://www.harborfreight.com/air-too...CategoryExpand
http://www.harborfreight.com/1-3-hp-...sor-97080.html
Mstrlucky74 is offline   Reply With Quote
Old 12-28-2013, 11:25 AM   #2
Rewards Points: 14,006
That compressor is about useless for a nail gun.
It has 1/2 the CFM needed to run even a 16 gauge nailer.
Need a gun that can shoot 2-1/2 long nails.
Old 12-28-2013, 02:45 PM   #3
Rewards Points: 878
Would I be better with this one?
http://www.lowes.com/pd_349204-70-C2...3D1&facetInfo=
Old 12-28-2013, 03:03 PM   #4
That would work fine.
Old 12-28-2013, 03:08 PM   #5
PoleCat's Avatar
Rewards Points: 1,652
The punkiest compressor will have no trouble keeping up with a brad nailer. Which is what you would want to use on molding. I got this little piece of junk at lowes that will not handle pumping up a flat tire but works fine with the brad nailer. You want a framing nailer then no go. Just saying.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 12-28-2013, 03:18 PM   #6
Rewards Points: 878
Wait so the compressor that I posted in my first post and this nailer will work fine together and is okay for crown molding?
http://www.harborfreight.com/18-gaug...ler-68021.html
Old 12-28-2013, 03:23 PM   #7
How are you going to install crown moulding with a brad nailer?
There's almost no head for holding power. And to small a gauge.
eandjsdad (12-28-2013)
Old 12-28-2013, 03:30 PM   #8
Rewards Points: 878
Originally Posted by joecaption
How are you going to install crown moulding with a brad nailer? There's almost no head for holding power. And to small a gauge.
That's my question
Old 12-28-2013, 03:41 PM   #9
Rewards Points: 153
You need a 16GA or even a 15GA nailer for trim. A lot of pros use 15GA and 18GA - some parts of the trim get heavier nails than others. If you had to use just one, probably go with a 16GA. Find it's CFM requirements, then match a compressor to it. Compressor pressure should go to 150PSI.
The worst that happens with an undersized compressor is you have to wait between shots - they all provide air out of the tank, it's just that the small ones can't keep up with how fast you can run a nailer.
eandjsdad is offline   Reply With Quote
The Following User Says Thank You to eandjsdad For This Useful Post:
Mstrlucky74 (12-28-2013)
Old 12-28-2013, 04:13 PM   #10
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
you dont need a 16 gauge or 15 gauge for crown, a 18 gauge works fine if nailed every 12" and even with adding glue to the back of it. ive run countless feet of crown using nothing more than a 18 gauge and never had issues. the only time i change guns is to use a 23 gauge to cross nail mitres
15 gauge and 16 gauge nailers are better for baseboard, window sils, hanging doors, closet shelf cleats.. anything that requires strength and holding power.. baseboard requires the heavier nailer because it takes abuse from vacuums, furniture bumping into it. the only thing crown has to deal with is occasional dusting
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
eandjsdad (12-29-2013)
Old 12-29-2013, 06:57 AM   #11
PoleCat's Avatar
That is nicer than the one I got. And I actually meant a finish nailer. It will shoot up to 2 1/2" nails.
Old 12-29-2013, 07:42 AM   #12
DIY staff
Rewards Points: 7,174
You will be sorry if you buy that tiny compressor---get the bigger one you pictured--
If Lowes is your store--look at the black Kobalt compressor--Nice small compressor
Old 12-29-2013, 08:10 AM   #13
K&B Designer
Live_Oak's Avatar
No one ever regrets getting more capability than they can currently use. They sometimes ramp up their skill level to be able to use it. Everyone regrets going underpowered on tools. It's beyond frustrating, even for someone who doesn't anticipate doing "much" work with it.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
The Following 3 Users Say Thank You to Live_Oak For This Useful Post:
BigJim (12-29-2013), joecaption (12-29-2013), PoleCat (12-30-2013)
Old 12-29-2013, 08:27 AM   #14
http://www.cpooutlets.com/factory-re...1=Porter-Cable
Old 12-29-2013, 09:35 AM   #15
Rewards Points: 878
I returned the other and got this. A little more than I wanted to spend but oh well. Thanks everyone.
http://t.homedepot.com/p/Porter-Cabl...671/204369377/
Crown Moulding - Inside corners. Moulding upside down? mb88 Carpentry 5 09-21-2012 04:37 PM
removing paint then staining moulding n0_oNe Painting 2 03-18-2012 08:19 AM
Crown Moulding Paint Peeling ryanb4614 Painting 6 01-23-2012 09:15 AM
Door Moulding Idea Help Vibber Carpentry 4 06-01-2010 07:51 AM
Crown Moulding and nailing davis_mc Carpentry 21 01-12-2010 10:52 PM
