Can I Stud New Ceiling Without Demo Of Old Plaster Ceiling. - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-15-2011, 09:56 AM   #1
Can i stud new ceiling without demo of old plaster ceiling.
I have a drop ceiling in my bathroom that I would like to remove but I don't want to rip the old plaster ceiling apart if I don't have to. Can I just stud out a new ceiling under the old and insulate it ?
Jj375 is offline   Reply With Quote
Old 08-15-2011, 10:05 AM   #2
Rewards Points: 5,336
Is this a second floor bath, with an attic above?
If so, why not insulate it from above.
If the plaster is structurally sound and you can't skim coat it, just install 1/4" sheetrock on top.
Supplying more details will help with suggestions.
Ron
B. Franklin 1759
Old 08-15-2011, 11:40 AM   #3
I'm trying to avoid the mess of removing the old plaster and blown in insulation above it. Right now I have a drop ceiling with wiring and duct work above it. None of this requires access. I just don't like the look of drop ceilings and would rather frame a new ceiling and sheet rock at the same height. The bathroom is small roughly 8•7.
Old 08-15-2011, 11:49 AM   #4
Rewards Points: 1,760
how high is the plaster ceiling and what would the finished height be of the new ceiling? You can always frame a new ceiling in; question is will it be livable and/or meet building code for habitation and resale?
bob22 is offline   Reply With Quote
Old 08-15-2011, 12:14 PM   #5
Existing plaster ceiling is 9' drop ceiling is 8'. I wouldn't be any lower than the drop ceiling.
Old 08-15-2011, 12:27 PM   #6
Experienced
Jackofall1's Avatar
I would just add the framing and new drywall but don't add insulation as there is undoubtedly a vapor barrier and insulation in the attic and you don't want to add insulation under the VB.
Mark
Old 08-15-2011, 12:46 PM   #7
There is no vapor barrier ,just plaster ,wood lath , the blown in cellulose insulation. Do I just attach ceiling to walls or do I need to tie into existing ceiling for support?
Old 08-15-2011, 12:50 PM   #8
Experienced
Jackofall1's Avatar
That would depend on the span, but I don't imagine its very much as it is a bathroom.
I would nail or screw a stringer to the walls and then joists to the stringer, just make sure you are screwing into wall studs.
Mark
Old 08-15-2011, 12:54 PM   #9
Rewards Points: 6,652
I left my rock-lathe up for my ceiling, but ripped all the walls down, when I redid my bath. Just went over where the seams were, with a couple of skim coats. Came out looking like a new ceiling. Now of course with our Kitchen dining and living room areas, we have come to the decision to lay 1/4" gypsum glued and screwed to hide the seams, because it would take too much work to fix, especially in the Kitchen area, where they did not put any sand paint on the ceiling to hide the imperfections.
Old 08-15-2011, 12:58 PM   #10
Mark
Span is no more than 7' what size stringer? 2•4 or 2•6? and would you use joist hangers or just nail to the stringer?
Old 08-15-2011, 01:44 PM   #11
Experienced
Jackofall1's Avatar
2 x 4 framing is all it needs nails would be fine
Mark
Old 08-15-2011, 01:45 PM   #12
Thanks for your help
Old 08-15-2011, 02:06 PM   #13
Experienced
Jackofall1's Avatar
You are so very welcome, you should post some before during and after pics, we all love to look at the projects accomplished.
Mark
Old 08-15-2011, 03:44 PM   #14
I would screw a perimeter frame to the wall studs and attach the ceiling joists to the frame.
Ron
B. Franklin 1759
Popcorn ceiling made of plaster strungoutfan78 Drywall & Plaster 12 10-31-2016 12:25 PM
peeling latex paint on old plaster ceiling rods2lug Painting 5 07-03-2011 03:38 PM
Stud finder not picking up ceiling studs Delta223 General DIY Discussions 9 03-26-2010 07:52 PM
peeling paint on plaster ceiling mspdet Painting 9 12-13-2008 07:45 PM
Cracked Plaster Ceiling..... SSandecki Remodeling 1 12-23-2005 08:16 AM
