Can I Round The Edge Of A 1x4 With This - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-10-2014, 05:33 PM   #1
Rewards Points: 874
I know it's cheap but I'm just asking. If so what size/kind of bit would I use? It's for a shelf. Thanks http://t.harborfreight.com/14-in-trim-router-61626.html
Mstrlucky74 is offline   Reply With Quote
Old 08-10-2014, 05:37 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,318
Sure you can....1/4 inch shank roundover bit in the radiuos you want
MTN REMODEL LLC is offline   Reply With Quote
Old 08-10-2014, 05:48 PM   #3
Rewards Points: 690
I concur. but radius, not some odd European thing.
ED
de-nagorg is online now   Reply With Quote
The Following 2 Users Say Thank You to de-nagorg For This Useful Post:
ben's plumbing (08-10-2014), MTN REMODEL LLC (08-10-2014)
Old 08-10-2014, 07:14 PM   #4
Rewards Points: 12,794
Even a sander can make that small a radius.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
ben's plumbing (08-10-2014), r0ckstarr (08-10-2014)
Old 08-10-2014, 08:19 PM   #5
Rewards Points: 92
Concur with joe. That is something I would just do with my random orbital sander. Ron
ront02769 is offline   Reply With Quote
The Following 2 Users Say Thank You to ront02769 For This Useful Post:
Old 08-10-2014, 09:01 PM   #6
You can certainly ease an edge with a sander.....
,,, Golly, I wonder why they even make roundover bits.... when you could sand them down....
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Old 08-10-2014, 10:26 PM   #7
r0ckstarr's Avatar
Rewards Points: 1,978
So, how much can that little trim router actually do? (I have a Ridgid trim router and am curious). Can it cut rabbets into a board?
r0ckstarr is online now   Reply With Quote
Old 08-10-2014, 10:35 PM   #8
Rock.... Honest talk...... it's pretty krappy..... I have one (second one) and 5-6 other routers.
That's probably the limit of it's capacity, small roundovers/edge work, minimal cut, laminate trim.
It is small and light, and for small edge work, and depending if it might have a 1/4 roundover in it for a pine board, I'll grab it.....
plus it's kinda like the fourth of July watching all the sparks come out of the motor....
Best
The Following 2 Users Say Thank You to MTN REMODEL LLC For This Useful Post:
r0ckstarr (08-10-2014), ratherbefishing (08-13-2014)
Old 08-10-2014, 10:38 PM   #9
r0ckstarr's Avatar
Best
I figured that much. I was just curious. I've only used it to trim laminate for countertops and it will bog if you go to fast there. Thanks for the input.
Old 08-11-2014, 09:58 AM   #10
Rewards Points: 310
As trim router, the base may not have a hole big enough even for quarter round bit. I think my Portercable does, but that's about it. Not worth the money for your purposes.
Using round over bit is the result is absolutely uniform and esp if you want a bullnose edge. Plane first then hand sanding may be enough for a small touch ups.
carpdad is offline   Reply With Quote
Old 08-11-2014, 10:38 AM   #11
47_47's Avatar
Rewards Points: 44
For just a few straight boards, I use a radius plane.
47_47 is offline   Reply With Quote
Vented drip edge installed instead of the edge vent User123 Roofing/Siding 8 07-19-2013 07:39 PM
The Edge Vent/Smart Vent and leafguard User123 Roofing/Siding 5 07-08-2013 11:31 PM
Curled edge repair + fascia install wonruger Roofing/Siding 1 05-20-2013 06:11 PM
Wet Edge on Walls: How Far Per Roller Load? Twister Painting 10 11-23-2011 05:28 AM
Ice and Water Shield under drip edge? sutterml Roofing/Siding 10 07-11-2011 06:04 AM
