#1 |
Can I replace a window from the inside?
Hi;
I realize that this may be a ridiculous question, but no harm in asking anyway... I would like to (eventually) replace my old attic windows. The house is around 80 years old, the windows are double-hung, originals. One side of the attic has two windows side by side with a moulding between, which houses the counter-weights. On the outside, there is aluminum siding over wood. What I would like to do is rip out the double window and install a fan with louvered cover, and maybe a window on one side or each side depending on the size of fan I install. On the other side of the attic there are two more windows, but these are seperated by the chimney. Same double-hung. I do not have a ladder long enough to reach the attic windows (about 30ft) and don't like to work on a ladder anyway, so I am wondering if it it is at all possible to install windows with access only from the inside. Thanks FW
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#2 |
Xtreme DIY'r
It is possible
I put several windows into my house from the inside on the 2nd floor The harder part is installing the trim But with a rope or something to secure you from falling out the window it is possible |
#3 |
You are much safer on a ladder.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it. |
#4 |
Moderator
Depends. If you replace the double hung with new kits, glazing, and jambs that happen to fit or are special order, yes.
Most D.H. windows are removable glazing, very easy from inside, including outside trim. Be safe, G |
#5 |
Xtreme DIY'r
Can I replace a window from the inside? |
#6 |
Sounds a bit too tricky for a first-time DIY.
Thanks FW
#7 |
Moderator
Yes, buy a kit: http://www.jeld-wen.com/zappack/ Be safe, G
#8 |
If the frames are solid, you can use vinyl replacement windows. They are installed from the inside.
Ron |
#9 |
Man of many hats
I agree. I have replaced many windows from the inside, even on the 10th floor of condos. The hardest part is taking the old window out, but since yours are wood, even that would not be hard for a DIYer. And if you replace them with DH vinyl windows, they are easy to install and trim from the inside as well as you can tilt in and remove the sashes for trimming and caulking.
Man of many hats |
#10 | |
Can I replace a window from the inside?Quote:
![]() GBAR, Ron and wrangler have the answer.
#11 |
I can't see how working on a 30 foot ladder with a 50 pound window is safe. If I was to replace an old wood window I would do it from the inside but putting aluminum capping on from the inside would be a whole other story. Take the old window out and shim enough that you can get spray around on all 4 sides ,make sure the shims are tight and spray. Fill it right up and forget the screws.
#12 |
Xtreme DIY'r
#13 |
Thanks for the help guys;
This is a long term project; One that I will consider "eventually". For now, I'm just getting an idea of what my options are. I don't know what shape the current window frame is in, but I can tell you that it's pretty worn. I may not know exactly what shape the old frame is in until I remove the old one. On the inside, I cannot see any real damage, but I don't know what it looks like under the aluminum. My replacement would not be a direct one, at least on the one side, since I want to rip out the center "post" and install a fan. I would like to learn something about framing windows and doors, but a visit to my local library was not fruitful. Can anyone recommend a good DIY book for this? Thanks FW
#14 |
Moderator
This site is great. Enter different titles, and look for preview at the bottom, read what pertains, move on. Be safe, G
#15 |
Moderator
Whoops, went to the dentist this morning. Here it is: http://books.google.com/books?ei=MNH...G=Search+Books Be safe, G
| Display Modes | |
| How hard to replace window screens? | TomBrooklyn | Building & Construction | 4 | 01-04-2009 10:03 AM |
| Keeping Egress Window Code Compliant | ClnlBrahm | Building & Construction | 2 | 09-11-2008 11:00 PM |
| Re-sizing a window opening | shtoink | Carpentry | 5 | 09-04-2008 11:47 AM |
| What router bit is used to create the inside angle on a window stool? | Mikedks | Building & Construction | 7 | 05-12-2008 05:43 PM |
| locate a vendor for vinyl window pane trim | bjr23 | Remodeling | 1 | 02-14-2005 12:59 AM |
