Can I Make My Dryer's Vent Line Better Looking? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-15-2013, 11:03 PM   #16
Sorry thats just not true
Screws are a violation
creeper is offline   Reply With Quote
Old 06-16-2013, 12:49 AM   #17
JOATMON
ddawg16's Avatar
Rewards Points: 1,810
I believe Creeper is correct....on dryer vents...no screws....they stick into the pipe and end up catching lint.....and adding to the problem.
Foil tape....
In my area (California, that state that everyone 'seems' to think has too many rules)....you have to use screws on single wall water heater and FAH vents....if you use B-Vent...screws not required (sections lock together).
Old 06-16-2013, 02:32 PM   #18
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,200
it must vary by region then because i have a canadian building code 6 ft from me and it clearly states no more than 2 screws per joint
woodworkbykirk is offline   Reply With Quote
Old 06-17-2013, 01:05 AM   #19
Pro
Rewards Points: 91
Obviously depends on location: California Mechanical Code 504.3.1 "... Ducts for exhausting clothes dryers shall not be connected or installed with sheet metal screws or other fasteners that will obstruct the flow. ..."
CarpenterSFO is offline   Reply With Quote
The Following User Says Thank You to CarpenterSFO For This Useful Post:
ddawg16 (06-18-2013)
Old 06-18-2013, 01:42 PM   #20
Rewards Points: 37
Thanks everyone for the great suggestions!
mystiky is offline   Reply With Quote
How to vent washing machine drain line nateo Plumbing 1 12-31-2012 04:43 PM
Ridge Vent Installed - what to do about soffits nickc3 Roofing/Siding 3 07-02-2012 04:26 AM
Complete blockage of main line mnp13 Plumbing 9 05-29-2012 10:51 AM
Vent sizing pment Plumbing 5 04-19-2011 07:21 AM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
