Can I Make My Dryer's Vent Line Better Looking? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-13-2013, 01:11 PM   #1
Rewards Points: 37
Question
Can I make my dryer's vent line better looking?
As you can see by this photo, our basement is getting completely redone. I am trying to figure out if there is a better (smarter and/or better looking) job with my gas dryer's exhaust line from the inside of my basement?
It's a standard 4" elbow, and the outside of the new frame ends up being 6 inches from the wall + the 5/8 sheetrock.
Are there any suggestions as to what I can do, so I can somehow improve visually how this all looks? I have plenty of space for my washer and dryer depth-wise. so space behind the units is not an issue.
Much appreciate all input, as always.
mystiky is offline   Reply With Quote
Old 06-13-2013, 01:30 PM   #2
Rewards Points: 13,300
Guess your not planning on insulating those walls judging by the way your laying the wall studs flat like that.
Not sure why your do it that way or using 2 X 6's. I would think your going to get more flexing and seam cracks that way.
Get rid of the flex line and use 2, 45 deg. elbows and solid galvinized pipe.
Old 06-13-2013, 01:49 PM   #3
concretemasonry's Avatar
Rewards Points: 2,578
Just get rid of the temporary flexible junk.
Dick
concretemasonry is online now   Reply With Quote
Old 06-13-2013, 05:33 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,060
not only is flexline ugly but its more prone to plug up over time from lint. this also can create a fire hazard.. use aluminum pipe for the final install.. its much cleaner looking and doesnt allow lint to collect
woodworkbykirk is online now   Reply With Quote
Old 06-13-2013, 06:31 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,112
Maybe an inline filter near the appliance as well
Old 06-13-2013, 07:28 PM   #6
Roofmaster
Rewards Points: 2,172
My neighbor was a firefighter in DC. Clothes dyers are the number 1 cause of residential home fires. With this in mind, it is pretty amazing that there is no swing down door under the drum where you can shop vac out the lint that collects under there. It is also amazing that the sale of corrugated or flexible plastic hose is allowed for this purpose. Use only smooth galvanized or aluminum pipe with the fewest fittings, and the openest flow path you can develop. Sorry WOW, but you most definitely do not want an inline filter that may be ignored, and you want to remove the lint every time you use the dryer (No Brainer there)
I remove the front panel, break down, and shop vac out my dryer about every 6 months. Not that I am proactive, its to get all the various hardware out of the blower section that I left in my pockets, that is now making hideous noises, as it rubs on the fan housing.
Old 06-13-2013, 07:34 PM   #7
Rewards Points: 1,458
You can start by using one of these:
http://www.amazon.com/Whirlpool-4396...ing+dryer+vent
ktkelly is offline   Reply With Quote
Old 06-13-2013, 07:58 PM   #8
The in-line filters are not designed to replace cleaning out the drier trap, just designed to keep the stuff that gets through from clogging up the pipes and creating an issue in the discharge pipe.
It is hardly and issue here once he/she swaps out to a rigid section, but for the folks that have long runs and a bunch of bends, keeping the lint that gets through the trap out of the line is a great thing and will actually prevent more fires.
Most of the units are glass faced so that they can easily be inspected and pro-actively cleaned.
The Following User Says Thank You to Windows on Wash For This Useful Post:
jagans (06-13-2013)
Old 06-13-2013, 09:06 PM   #9
Roofmaster
Thanks Eric, Ive never seen one.
Old 06-13-2013, 11:32 PM   #10
Lord of Slums
Rewards Points: 1,974
http://www.iaqsource.com/product.php...product=175398
mj12 is offline   Reply With Quote
Old 06-14-2013, 06:23 AM   #11
Originally Posted by concretemasonry View Post
+1
Dick
And don't forget to use tape on the seams and not screws for the lint to get built up on
creeper is offline   Reply With Quote
The Following User Says Thank You to creeper For This Useful Post:
concretemasonry (06-14-2013)
Old 06-14-2013, 08:08 PM   #12
you need screws to hold it togehter. tape will let go.. only use 2 screws per joint though.. and FOIL tape not Duct tape
Old 06-14-2013, 09:59 PM   #13
Lord of Slums
Make sure the seams are lapped in the proper direction, I use pop rivits and metal tape. Supposedly the screws caught lint and are a fire hazard
Old 06-15-2013, 09:57 PM   #14
I think you should stick to carpentry because screws in your venting is a horrible idea. Just stick to foil tape
ahrens is offline   Reply With Quote
Old 06-15-2013, 11:29 PM   #15
, its in the canadain building code to use screws. but a maximum of two per joint. tape can fail if the pipe is knocked around at all trust me ive seen it happen. the screws will hold
How to vent washing machine drain line nateo Plumbing 1 12-31-2012 05:43 PM
Ridge Vent Installed - what to do about soffits nickc3 Roofing/Siding 3 07-02-2012 05:26 AM
Complete blockage of main line mnp13 Plumbing 9 05-29-2012 11:51 AM
Vent sizing pment Plumbing 5 04-19-2011 08:21 AM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 03:56 PM
