Can I Add On To My Bottom Tread? - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-21-2010, 10:25 AM   #1
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
Can i add on to my bottom tread?
Hello. Iam redoing my stairs from carpet to hardwood and i was wondering if i can add on to the bottom tread to somewhat wrap it around where you see the wood on the floor. It would extend about 6" out that way . Is that allowed or by code would it have to stick on 11" on that side?
ryanh is offline   Reply With Quote
Old 07-21-2010, 03:27 PM   #2
Rewards Points: 5,336
They sell or you can make a longer base step with a curved tread over it. It's commonly used with a volute.
In your case, you can build an extension to the stair and put a tread with a curved end over it.
Ron
Old 07-21-2010, 05:07 PM   #3
Old School
Willie T's Avatar
Installing a railing
Willie T
Old 07-21-2010, 08:28 PM   #4
Rewards Points: 1,910
Looks like you also need to fix the uneven riser heights to meet code. Your bottom riser looks too short after the flooring was added.
Old 07-22-2010, 12:07 AM   #5
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
I agree
WirelessG is offline   Reply With Quote
Old 07-22-2010, 06:39 PM   #6
ryanh's Avatar
Rewards Points: 154
Nah the risers are up to code, the bottom one is 7" just can't tell from the camera angle. Stairs had carpet just replacing with hardwood stairs.
Im going extend the bottom step tomorrow not sure if i will 45 it or 90 the corner though
Bosch Dishwasher leaking along bottom seal of door mtbdudex Appliances 14 10-13-2012 09:49 AM
HELP PLEASE replacing rotted sole, top and bottom plate dolson Remodeling 4 04-16-2010 07:54 PM
Need to build stairs--Is there a Stair Kit? Cocoxoxo Building & Construction 13 04-15-2010 09:52 PM
SW Tread plex & over helpful contractor Wahiawan Painting 2 11-13-2008 11:35 PM
Repairing Broken Stair Tread RonnyK Carpentry 1 05-17-2006 02:37 PM
