Can Anyone Identify This Planking (Picture Included) - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-23-2012, 10:39 AM   #16
Bombastic Idiot
notmrjohn's Avatar
zap, Mr Hoadley's a idjit, that's obviously plastic.
Easiest way to tell them apart is with simple tool, a match. If it burns its wood, if it melts plastic. If it smolders, giving off toxic fumes composite.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 10-23-2012, 10:39 AM   #17
funfool's Avatar
Rewards Points: 534
Just reading through this thread. Couple thoughts I had, is wood and and trying to match it exactly may be almost impossible.
I use a similar product in interior use, it is 5/8" x 51/2" tongue and groove spruce.
I buy it from a real lumber store, they warned me last year.
Company they buy it from, updated their milling tools. Even though it looks the same, the old style will no longer interlock with the new, because of the tool change.
I would suspect that you may find something that looks the same, may not fit with the old.
You may need to remove some of the old and just use new in a isolated area as under the stairs.
Will be close enough that no one will notice.
You could spend hours and hours trying to get the exact same thing, how much is your time worth?
funfool is offline   Reply With Quote
Old 10-23-2012, 10:46 AM   #18
Bombastic Idiot
notmrjohn's Avatar
matt, its been a month now. We're all waiting, to the point where we're getting repetitious, to see if you matched it and what it is, or if you got a close match and swapped it out.
Old 10-25-2012, 07:43 PM   #19
If the color on my computer screen is right it could be pumpkin pine especially if your home is older. If it is you would most likely have to find it at a salvage yard. Take the piece you have to a specialty lumber yard where they sell different types of hardwoods and show it to someone there. They should be able to tell you exactly what you have there.
ewryter is offline   Reply With Quote
Old 10-25-2012, 08:44 PM   #20
try using a clothe iron and a wet towel on some pine boards steam will raise the grain let dry and give a light sand finish with a poly hope it works for you as well as
it has for me in the past
hammersmit2001 is offline   Reply With Quote
Please help me identify this tile jsoldatot Flooring 4 04-29-2012 07:47 PM
Help Identify Joist-Frankenstein Boiler98 Roofing/Siding 1 03-11-2012 04:01 PM
Tankless gas line opinions .. picture included beachfront71 Plumbing 1 05-10-2011 05:36 PM
Help me design a closet (picture of room layout included) DannyUpper90 Remodeling 6 01-07-2011 11:29 AM
Bathroom Timer Fan Help - Picture included :-) whattheheck Electrical 4 11-12-2008 01:31 PM
