Cambell Hausfeld Compressor Problem - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-28-2011, 04:01 PM   #1
cambell hausfeld compressor problem
compressor stopped working, replaced switch, runs fine, air is going through the tank but wont charge and shut off
ebby is offline   Reply With Quote
Old 09-28-2011, 04:09 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
"air is going through the tank"?
What does that mean exactly?
Old 09-28-2011, 09:02 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
sounds like "car for sale runs great needs new engine!"
is the drain valve closed, if the motor is running and its not filling up theres a good chance the diaphram is gone. this is typical of oil less compressors. the porter cable pancakes suffer from this, the solution .... buy a new compressor , as reccommended by the repair shop guys
woodworkbykirk is offline   Reply With Quote
Old 09-28-2011, 09:11 PM   #4
KemoSabe
loneframer's Avatar
Step 1. Take the top off of the pump. There's a chance that there is debris stuck in the intake valve. This will allow the intake air to be exhausted back out and not build tank pressure. I've seen this occur on a 150 dollar oil-less pancake compressor, as well as an 800 dollar blue Emglo. It's worth a shot before replacing.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 09-28-2011, 09:20 PM   #5
Rewards Points: 150
I think that the above is good advice. You could also try to hard wire it so in is on. Make sure you buy another more quality unit soon you will be glad you did.
OhioHomeDoctor is offline   Reply With Quote
Campbell hausfeld air compressor wont start Steve12 Tools 25 03-04-2011 09:17 PM
2 gallon air compressor combo - Campbell Hausfeld or Husky? whataboutj Tools 3 11-26-2010 03:31 PM
CampBell Hausfeld Compressor problems Hexar Tools 13 11-23-2010 07:23 PM
Campbell Hausfeld (electric) 1500psi pressure-washer problems Eric VB Landscaping & Lawn Care 0 06-12-2010 05:50 PM
Bostitch VS Campbell Hausfeld nailers. Jim F Tools 4 04-25-2010 02:50 AM
