-   -   cambell hausfeld compressor problem (http://www.diychatroom.com/f14/cambell-hausfeld-compressor-problem-118588/)
ebby 09-28-2011 03:01 PM
compressor stopped working, replaced switch, runs fine, air is going through the tank but wont charge and shut off
Bud Cline 09-28-2011 03:09 PM
"air is going through the tank"?
What does that mean exactly?
woodworkbykirk 09-28-2011 08:02 PM
sounds like "car for sale runs great needs new engine!"
is the drain valve closed, if the motor is running and its not filling up theres a good chance the diaphram is gone. this is typical of oil less compressors. the porter cable pancakes suffer from this, the solution .... buy a new compressor , as reccommended by the repair shop guys
loneframer 09-28-2011 08:11 PM
Step 1. Take the top off of the pump. There's a chance that there is debris stuck in the intake valve. This will allow the intake air to be exhausted back out and not build tank pressure. I've seen this occur on a 150 dollar oil-less pancake compressor, as well as an 800 dollar blue Emglo. It's worth a shot before replacing.
OhioHomeDoctor 09-28-2011 08:20 PM
I think that the above is good advice. You could also try to hard wire it so in is on. Make sure you buy another more quality unit soon you will be glad you did.
