Calling All Cabinet Makers! - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-22-2010, 11:21 PM   #1
I have 12' of base cabinet, 54",36"(sink), 54". Cabinets will be all 3/4" ply. There is a slight chance I may go to 1/2" ply. Cabinet will be 28" deep.
Do I build 3 separate cabinets or a single 12' ? With 8' sheets, and a 12' cabinet, where to I make the seams? With 3 separate cabinets I either end up with double 3/4" pieces on the 2 middle divider walls, or a single 3/4" divider. With a single i would probably use a 1/8"x3/4" on either side of the panel.
Moving a 12' would be a little more of a problem, but it can be done.
Been looking for slides longer than 22" but no luck yet.
Thanks for the replys!
Hardhead is offline   Reply With Quote
Old 06-22-2010, 11:51 PM   #2
I would build separate cabinets. You may want to take one out later to install a DW or wine cooler.
hayewe farm is offline   Reply With Quote
The Following User Says Thank You to hayewe farm For This Useful Post:
Hardhead (06-23-2010)
Old 06-23-2010, 07:27 AM   #3
DIY staff
Rewards Points: 7,174
The depth you mentioned was 28"--Standard is 24" is there a reason for the extra depth?
Old 06-23-2010, 08:01 AM   #4
More room. Actually I have about 34" from wall out to corners on L and R. Might as well use the space. I also want to wrap the cabinets on the Left side around a corner and tie into a Refrig area with cabinets above. I always hated the small area behind sink with 24's. Uppers will be 16".
Old 06-24-2010, 06:31 AM   #5
DIY staff
When I build cabinets,I build the sections as large as I can handle. That extra width might made the harder to fir through a door--I'd check that first.
I find it faster to build and install.----Mike---
Hardhead (06-24-2010)
Kitchen sink not centered. gmhut Plumbing 5 06-01-2010 12:44 PM
Hello Cabinet Makers jaewal Introductions 3 10-27-2009 12:49 AM
hanging 9" kitchen cabinet (wall) and hit air duct, no stud phunam04 Building & Construction 4 06-16-2009 11:08 PM
Installing kitchen cabinet in precise manner janny Carpentry 8 01-15-2008 11:59 PM
cabinet maker's finish jim_k Painting 5 08-03-2007 02:37 PM
