Cage Modification - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-02-2011, 03:58 PM   #1
cage modification
Hello everyone. I have three vision cages model # 222. I love these cages except for the one flaw of haveing a huge cup holder sort of thing for a light dome. the cage is made of impact-resistant polyethylene and I dont have the slightest idea of how I would remove this thing.
any help would be appreciated.
thank you.
Alejandro45 is offline   Reply With Quote
Old 05-02-2011, 04:33 PM   #2
Old School
Willie T's Avatar
Isn't that for a ceramic heat emitter?
Willie T
Old 05-02-2011, 04:40 PM   #3
Its for a heat lamp mostly. But I live in a hot and humid place and extra heat would be unssesary and I want to remove it for more cage space.
Old 05-02-2011, 06:03 PM   #4
Old School
Willie T's Avatar
Considered a router with bit 1/4" wider than the guide bearing? Just run it around the inside rim of the hole.
Willie T
Old 05-02-2011, 06:25 PM   #5
Thats perfect!! I was going to go with wire and a hot pen but a router is just so much cleaner of a cutter! Thank you very much
Old 05-02-2011, 11:27 PM   #6
Registered User
Rewards Points: 526
If the same diameter, cut the bottom with grill off and glue that back on the shortened tube...., unless you want the open hole for feeding.
Gary
Reptile Cage Finished Marc10edora Project Showcase 21 11-16-2010 05:20 PM
Blower squirrel cage Dbenzboy HVAC 4 08-27-2010 08:05 PM
Trane Aux heat modification tj1mcd HVAC 2 12-05-2009 07:24 PM
5inch filter modification tut? silent1643 HVAC 5 07-16-2009 10:30 AM
Squirrel cage motor in air handler...no start andyinrichmond HVAC 13 03-15-2009 03:53 PM
