Cabnet Repair - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-12-2007, 07:48 PM   #1
Cabnet Repair
Greetings--
"Builders" type cabnets in kitchen. They have what, at first, apears to be a painted surface. However, upon closer inspection, it looks like its some sort of laminate cover. It appears that it was heat-formed ? onto the doors and drawers and glued.
There are two doors that the center section is "loose", comming away from the door itself. Several other doors and drawers's coverings are coming away from the inside edges.
Can these be fixed ? or is it a replacement situation ?
So far , three of the houses we've looked at have the same cabnets (same builder) and two have the covering becoming detached.
Comments ?
Piney is offline   Reply With Quote
Old 07-12-2007, 08:54 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by Piney View Post
Greetings--
Comments ?
I know the kind you are writing about. They cannot be fixed.
- Build Well -
Old 07-12-2007, 08:56 PM   #3
can you post a photo of the loose sections?
redline is offline   Reply With Quote
Old 07-12-2007, 09:29 PM   #4
Home Depot carries white doors made the same way. They have various sizes.
Stop by and see if they are a match (pattern-wise), and if they would work for an inexpensive - "swap out"....
- Build Well -
Old 07-12-2007, 10:34 PM   #5
remodeling pro
There is no way I am aware of to fix this. This is actually a vacuum formed very thin vinyl overlay , that always seemed brittle and a very poor grade of material to me. I have not seen them release in the center as you describe, but they are notorious for peeling at the back edges of the doors.
troubleseeker is offline   Reply With Quote
Old 07-15-2007, 10:10 PM   #6
Extreme DIY'r Adk's, NY
Rewards Points: 272
yes, these stink... especially if they EVER see any moisture. cheap cheap cheap
Last edited by AtlanticWBConst.; 07-16-2007 at 05:35 AM. Reason: Minor language reference
crecore is offline   Reply With Quote
Help Repair Garage Wall - Advice RandomJustice Building & Construction 8 07-28-2007 11:02 PM
Edge of roof deteriorated, how to repair? (pics) diymonkey Roofing/Siding 3 06-23-2007 02:02 AM
How do I repair my window frame sherlock Carpentry 18 12-20-2006 09:54 AM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 08:10 AM
